Post your best Pic
Fastway135
149
Mass
Here's mine. Not a great picture but theres not i can do in my driveway. Don't mind the gauge, I was testing out different locations. lol
Here's mine....'89 Turbo
Zerocool said:
Nice 89 you have there :) where in phoenix are you at?
Thanks guys!
I'm up in Cave Creek...worked on that motor for a year...pretty much every part has been upgraded. Got a SP61GT turbo on it and a really long list of supporting mods. I was going to wait on the paint job, but had a guy turn into me about half mile from my house (see pic). So he got to help pay for my paint job.
The wheels are made by a company called RPM...18x8 w/ 235/40 on the front, 18x9 w/ 275/35 on the back. Tires are Falkens...wheels have a 38 offset. The rims weigh in at just over 20lbs...not too bad.
supra90turbo
shaeff is FTMFW!
MA, 01440
Aw christ, jdub... that sucks..
At least the paintjob will be easier on your wallet now, though...
Good thing nothing bad happened to the wheel, too.
Clint
AzSupras
Apr 4, 2005
1,464
7
Mesa, Arizona, United States
jdub said:
Thanks guys!
:3d_frown: that sucks bro :( hopefully you will have her back on the road soon enough that way you can make it to some meets! :)
Awwhh...thanks for the kind words guys, that was a "before" pic.
I finished my motor build in late Aug, put it in, and got to drive it for a whole 3 weeks, then this guy turned into me. It went into the body shop in mid Oct and they took it completely apart, block sanded, modded the front bumper, modded the head light covers (they really work as ducts too), and painted it pearl white...took them over a month. I had the wind shield replaced and the back hatch glass too (waited for 2 weeks for hatch glass to ship from Japan)...all the window trim was replaced and went with the clear front signal/markers. Got it back in early Nov and now she looks like the 1st pics I posted. I installed low profile fog lamps so the stock hole can function as vents...the tranny cooler is behind the divers side one. Body wise, I'm trying to figure out what front lip to get and I'm modding a set of front trim with clear markers to match the back.
Sooo, The new motor has been broken in now for about 2 weeks after all this (couple of oil changes). Mechanical wise, I've still got to install a 3.90 diff w/ a TRD LSD in it, aluminum drive shaft, Walbro 255 fuel pump...hope to get the pump in this week. I need to re-shim the valves too...I used 1mm oversize valves w/ upgraded springs and they need a re-adjust. Gonna check the head stud torque while I'm there.
After all that is done...gonna install an AEM ECU and change to a temp density set-up with a fuel curve based on boost. The SP61GT turbo (it's the one with the wastegate built into the downpipe) boosts very fast to 18-20 psi and then I hit fuel cut...I can't even floor it because it boosts so quick. The AEM is going to control boost in this set-up.
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
sorry to hear about your car man, you and sarichmond both, you two had clean clean supras, so why did they have to get hit, its almost like the cleaner your MKIII is the more it says run into me
