post a picture of ur custom trunk set up
Fastway135
149
Mass
Here's my extremely basic setup when I first got it in before I got to hiding the wires. Not the loudest but gets the job done on the inside.
fiyota
I ♥ Boost
May 3, 2006
1,063
Kelowna, BC
before I steam cleaned my trunk and I'm going to recover that box.... and yes, the hatch does close completely haha... locked my keys in the car testing it.... "oh there's no way this will fit..." as the latch clicks... those JL subs sound amazing tho :icon_bigg
fiyota
I ♥ Boost
May 3, 2006
1,063
Kelowna, BC
those W0's? How you liking them? Running two 12's I hit 136.5db.... not bad for $99 a piece subs running on a $200 amp
ross1
188
va
it's actually all been pulled i'm chucking one of the subs and lowering the box more to a size like supraman's (a little taller) even with the hatch area and only gonna use two of them. but when they were in sounded great as it was all with boston acoustic fronts, now i've got a matching set of JL 6.5 components for the front and gonna get something else for some rear fill, this is all after the rebuild (or new motor) then try to run an in car pc like somebodies post i just was reading a week or so back...
ross
hot dayam mk3
149
here's mine, cheap and does wonders....
i need to finish making the custom fiberglass box for the battery relocation and amp.
hot dayam mk3
149
its the ebay one..... it would be good as the original if i could make brakets simular to the do-luck one.
robeats91t
237lbs. of Ballast
Jun 4, 2005
210
Tampa, FL
Heh, mine's more "store-bought" than "custom" right now, but it allows for targa storage, is easily removable, and took about 3 seconds to install. The amp was another story--I spent some time fitting it under the passenger's seat, but it's almost perfectly hidden. The system actually sounds pretty good, to me; I like bass, but I don't want people a block away to hear me coming. 10" SVC Rockford Fosgate driven by 400w Kenwood Amp...has worked flawlessly for me for the past 5 years or so.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
heres mine. two audiobahn se 10" with a 4002T amp. not bad, i built the box myself but havent gotten the time to carpet it yet, so it still looks like shit. cant figure out how to hide the wires, either.
canadian
Newbie
May 16, 2006
366
Victoria BC
How do the audiobahn subwoofers sound?
