poly bushings feedback
ronniek
Authorized Vendor
May 2, 2005
274
auckland
Has anyone got any feedback on quality,fitment,wear so far of the poly suspension bushings I sell through suprasport.
I also would like to know what are poly suspension stuff would people be interested in?.
Thanks,
Ronnie K.
becauseican
Vancouver
www.bicperformance.com
Ronnie,
Are the rear lower #1 and #2 bushings you make for the inside/ subframe end of the arm or for the spindle end?. I need the rear knuckle/ spindle bushings badly, let me know if you make them. If not, you should, I will buy a set right now. Also will the front upper bushings work on the rear upper control arms?.
ronniek
Authorized Vendor
May 2, 2005
274
auckland
The front upper bushings are the same for the rear upper bushings.
The rear lower #1 and #2 bushings are for the inside subframe end of the arm.
I will have a go at making the knuckle/spindle bushings.
Thanks,
Ronnie.
Are the rear lower #1 and #2 bushings you make for the inside/ subframe end of the arm or for the spindle end?. I need the rear knuckle/ spindle bushings badly, let me know if you make them. If not, you should, I will buy a set right now. Also will the front upper bushings work on the rear upper control arms?.[/QUOTE]
