I just installed a rebuilt head with headwork on my 7mgte and I'm getting some odd compression test numbers on a cold engine:
1. 95
2. 110
3. 118
4. 65
5. 90
6. 122
Now I know your thinking bhg but...
1. HKS stopper headgasket never even fired up, reused, inspected, viton throughly removed, copper sprayed all layers
2. new ARP head studs at 90 ft-lb
3. new revv oversized valves
4. cam marks line up at 0 degrees
5. all valve shims within spec
6. resurfaced head 0 miles
7. resurfaced block 500 miles ago
8. just before I removed the old head i did a warm engine compression test: 1. 155 2. 118 3. 142 4. 140 5. 134 6. 144. I contribute the old poor numbers to a warped surface which was eliminated since I got a new head. BUT this should eliminate piston rings as an issue since they were better before.
What am i missing here? Its gotta be a huge leak somewere.
Thanks,
Dennis
<Edit IJ> For those among us that either can't see or can't read.... :nono:
1. 95
2. 110
3. 118
4. 65
5. 90
6. 122
Thanks,
Dennis
