NGK NTK Wide Band Powerdex AFX Wideband... Anyone use it?
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Wondering any opinions on this wideband... I've found them for about $250 with everything... Are they compadible with AEM?
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
tissimo said:
NTK wideband with sensor for around 250$ where?
IJ did it come wiht a bosch sensor or ntk sensor?
Justin, I saw them on sparkplugs.com and started looking around and found them all over ebay for the $250 mark... Everywhere I read, it said Bosche O2 sensor... Is the NTK crappy?
Oh, and if IJ is rockin one, then I feel good about gettin one... :D:D:D
tissimo
Stock is boring :(
Melbourne, FL
NTK sensor is more robust and handles leaded gas a LOT better then the bosch.. I dont know much about the NTK sensors and not sure the difference between the L1H1/L2H2 or wahtever, I just assumed there was only one.
Jan 25, 2007
27
Burbank, CA
I just purchased one but haven't installe it yet. I'm waiting till I install my turbo first. The instructions say that this is for tunning only and that you should not keep the sensor on the rest of the time. At least that's what I got from it becasue it comes with a plug for the bung.
IJ, can you tell me if you keep the sensor plugged in all the time or do you just keep it on when you're tunning?
Doc: 100% Certain as I have the Bosch box here ;)
(I asked the guy where I bought it as I thought it odd and he told me about the Honda deal but maybe that's just an Aus thing?)
It uses a free air calibration routine so in theory you could plug in any Sensor.
TE: I keave it in as that's why I bought it instead of using the onboard WB02 in my ECU so I would have a display without having to have the Laptop in the car (Wolf can only run their Dash and can't output to an ext gauge or display like AEM)
bfr1992t
The quiet one
Oct 29, 2005
272
Ohio
I bought a bunch of NTK L1H1's that came in Bosch boxes. Check the sensor, the brand and part number should be stamped on the side.
bfr1992t
The quiet one
Oct 29, 2005
272
Ohio
IJ, cool, thanks.
Nice location. Reminds me I need to search for the acoustic version of another song that was used on Scrubs.
figgie
Twin Cities, Minnesot-ah
Ok folks
just got back a reply on this very question straight from NGK :)
Kristopher Zdral said:
Hello,
Thank you for your interest in the Powerdex AFX. The unit is originally supplied with a Bosch wideband sensor. The replacement sensor offered for the AFX is an NTK sensor 24302. Thank you.
Kristopher Zdral
Product / Sponsorship Coordinator
NGK Spark Plugs (U.S.A.), INC.
there you have it :)
