Need to block off recirculating valve inlet on stock accordian
huntin5L
Niles, IL
Anyone know what I need to block off that inlet on a stock accordian pipe. I will be putting on an intercooler kit, which has a bov and this is the only thing stopping me. I need to block off that inlet where the recirculating valve plugs into on the accordian.
Let me know, Thanks Bob
SUPERSNAIL
You have much to learn...
Nov 13, 2008
71
Albuquerque N.M.
Autozone sells all different sized thick rubber caps, Just find one that fits, Thats what i did.
huntin5L
Niles, IL
Crap, I am going to have problems venting to the atmosphere?? Assuming I need to put a hose from the bov to where the 3000 pipe would be, correct?
mkiii222
Troy, MI
Other way 'round.
It looks like that BOV does recirc. Just route the hose to the accordian and then you don't even have to worry about running to AZ, unless you don't have the hose and then you'll have to go anyways.
huntin5L
Niles, IL
mkiii222;1258778 said:
Other way 'round.
You can't see it, but there is no inlet on these new pipes like it has on the 3000 pipe. Just that long tubing coming off the bov that goes into, well look at the pic attached. This is how he had it running. Hopefully it will be fine.
dumbo
1,911
Albera, Too Far North
Me neither but I have a MAP sensor. Some things you can cheap out on, but when it comes to the mechanics of things Toyota did these things for a reason.
92nsx
2,957
Clearwater, MN
What is going to happen when you don't recirc your BOV it will stall the engine. READ. Since your HKS (or china HSK) BOV is already set up with a nipple, just drive down to the parts store and buy a foot or two of bulk heater hose(.75 cents a foot) and attach one end of the hose to the BOV and the other end to the accordian hose where the OEM BOV hooks up. Then block off the hole in the 3000 pipe. and BAM your done, no stalling, no problems.
You ask for help or what is going to happen, and we tell you. Don't say "Screw it, I am going for it" :nono:. Rather say/post thank you for helping me.
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
huntin5L;1258963 said:
Screw it, I am going for it. Others here have bov's and don't have any issues. We will see what happens.
you don't need to recirculate it, mine isnt, but you DO need to change the way you drive. You need to down shift and engine brake until your RPMs are low enough (around 2500), not to be boosting and clutch in...
