name that engine!!!
Jeff Lange
Administrator
4,919
Sunnyvale, CA
jefflange.ca
Pretty sure the 2JZ-FSE is a direct-port injection DOHC engine with VVT-i, can't remember if it had VVTL-i or not... it's pretty recent... like 2000+ I think.
Wanna say it came in the Crown, but I think it came in something else too...
Orion ZyGarian
Jeff Lange wannabe
Apr 2, 2005
1,490
Sarasota, FLorida
www.suprastore.com
Yes, the 2JZ-FSE is the 2JZ with direct injection and F heads (why not keep G?). VVTi, probably VVTL-i because of how much newer it is over the 2JZ-GTE. Only car I've seen it in is the Crown "Estate" or whatever the station wagon is!
supra90turbo
shaeff is FTMFW!
32
MA, 01440
L89 sounds like an RPO code... not an engine code...
DT466 is a CAT diesel 466cid
and can we follow the rules a bit? there's only one rule....
it kind of went crazy mid-thread...
everybody sit back. guess, if you will, but lets just try to name one code each, but ONLY if you get one correct.
right now it's kind of a free-for-all...
supra90turbo
shaeff is FTMFW!
32
MA, 01440
right.. cuz honduh is lyfe.
although i would like a k20a full ITR drivetrain in an EK hatch...
ok. what about G25A to keep the game going?
and Orian, you are correct. the VE30DE is a DOHC chain driven 3.0L v6 with variable valve timing on the intake cam, and was only available in the US in the nissan maxima, years 91-94.
sounds like an m3 when its uncorked. it's got that "noise" that's not quite an engine singing, but a whole bunch of racket. that raspy m3 noise... it's strange, but it sounds awesome.
Orion ZyGarian
Jeff Lange wannabe
Apr 2, 2005
1,490
Sarasota, FLorida
www.suprastore.com
If I had a choice of any Honda to build...the NSX would obviously be everyone's first. But my second would be the Odyssey...big block Honda.
Back to the game....is it a Dodge 2.5 4 banger, probably the 2.5 in the caravan, LeBaron, 300, etc. etc. all of those old late 80s early 90s?
supra90turbo
shaeff is FTMFW!
32
MA, 01440
yeah! the C30A is an awesome engine. turbo'd nsx's are incredible. the turbo is visible from behind the car in most kits. it's just so good.
www.scienceofspeed.com is a ridiculous nsx tuning company
and about your guesses: no, nope, no, no, and no, sir.
