Mystery cam bolt stripped! SOLVED
Albert
May 13, 2009
1,710
Tempe, AZ
So I got my boost controller working last week and after a couple 22psi pulls I parked my car at my buddy's shop to cool down. My buddy then decided to back up a truck that has BHG and proceeds to rev and dump BHG smoke all over my supra. I quickly jumped in my car to roll up the windows and out of instinct started my car. Since it was started I figured I would antilag scaring him to stop.
The car immediately died as I started antilaging. I proceeded to try to start the car back up but it sounded like I had a dead piston. Now I'm like "great! The 22psi pulls melted a piston"
I then noticed my cam bolt wasn't turning when trying to start:(clear timing cover FTW)
http://youtu.be/sFZcCyBFO4M
I took the cams out and down to my shop for repair. Here is what I found:
Exhaust cam threads stripped out and dowel pin was sheared right off
Looks like the threads of bolt were only engaged 3-4 threads deep. Out of the full 1" deep threads on the cam. I compared the HKS cam gear with a stock one and found out the HKS cam gear is twice as thick as the stock gear.
The dowel pin was only sticking .075 into the Hks cam gear where as the stock cam gear the dowel would sit flush with the stock gear.
So I decided to make a dowel pin out of 4340 that is longer so that it would sit flush with the HKS cam gear:
I put the cams into my machine and drilled them out and tapped them to 1/2-20 since the pitch is off .001. I then got a longer bolt that would engage all of the threads before bottoming out.
Thinking I solved the issue and what caused it was insufficient threads/short dowels/over tightened bolt. Boy was I wrong
After reinstalling everything, when I would go turn the motor over manually the motor would bind up. I for sure though I had bent a valve with the BC 272s
After poking around I noticed something strange on my exhaust shim/bucket in cylinder #4
Well I spit a shim! That's what caused the threads to strip and dowel to shear.
After doing some research the cause of me spitting a shim was in fact the antilag. The backfires could backfeed onto the exhaust valves relaxing the tension in the spring. If the timing is right, bye bye shim.
Carnage:
The bucket wouldn't come out so a nut was welded to it onto a slide hammer. Came right out
Cleaned back up:
1zz shimless buckets are in there way now
Discuss
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
I'd say you should consider yourself lucky that you aren't in need of a head rebuild. Hopefully that valve stayed straight through the whole ordeal.
MightyAl
293
Chesterfield, MO
I was thinking that this story better end with shimless buckets or I am going to be very sad.
So were any of the cam lobes damaged at all from this happening?
Backlash2032
1,823
Nebraska
Is this on a 7M or 1J? If its a 1J, the internals of the head look almost identical to a 7M
Sent from my terrible HTC Rezound using Tapatalk. Don't buy HTC...
Albert
May 13, 2009
1,710
Tempe, AZ
Right?! We leak down that cylinder, and when the damage was getting cleaned up we rotated the cylinder all the way up to drop the valve onto it and it all felt really nice. It didn't hang up at all.
Albert
May 13, 2009
1,710
Tempe, AZ
No. Small little ding on the outside of the cam lobe, and I mean little. Measures the same. So I say ts fine
Albert
May 13, 2009
1,710
Tempe, AZ
Yeah 7ms, 1jz, and 2jz all look the same in the head area. So do a lot of toyotas just the sizing is different
Albert
May 13, 2009
1,710
Tempe, AZ
They also have the same looking block internals with a crank, some rods and pistons and shit
Backlash2032
1,823
Nebraska
Lol.. I can tell the difference between a JZ and a 7M by looking at the bottom end though. :p
Albert
May 13, 2009
1,710
Tempe, AZ
BlackDevilSupra;1899659 said:
Great that the motor / head was essentialy unscathed. Keep us udpated with the process with the shimless buckets.
Yeah I lucked out
te72
Classifieds Moderator
6,625
9
WHYoming
I can do one better. I just put a cup under the engine. If I'd stick a straw in it, the engine must be a 7m. :rofl:
I keed. Albert, you're a lucky SOB sometimes. Lesson learned, check to make sure bolts are long enough? I mean that wasn't the root cause, but would that have helped? Or just made things worse if the cam bolt didn't give?
Just in case it's needed ;)
1SZ-FE 1000cc Echo
13751-23030 5.12
13751-23040 5.14
13751-23050 5.16
13751-23060 5.18
13751-23070 5.20
13751-23080 5.22
13751-23090 5.24
13751-23100 5.26
13751-23110 5.28
13751-23120 5.30
13751-23130 5.32
13751-23140 5.34
13751-23150 5.36
13751-23160 5.38
13751-23170 5.40
13751-23180 5.42
13751-23190 5.44
13751-23200 5.46
13751-23210 5.48
13751-23220 5.50
13751-23230 5.52
13751-23240 5.54
13751-23250 5.56
13751-23260 5.58
13751-23270 5.60
13751-23280 5.62
13751-23290 5.64
13751-23300 5.66
13751-23310 5.68
Nihiliz
Die Hard Supra Fan
Jul 23, 2007
307
United States
www.facebook.com
1zz's here i come!
1SZ-FE 1000cc Echo
13751-23030 5.12
13751-23040 5.14
13751-23050 5.16
13751-23060 5.18
13751-23070 5.20
13751-23080 5.22
13751-23090 5.24
13751-23100 5.26
13751-23110 5.28
13751-23120 5.30
13751-23130 5.32
13751-23140 5.34
13751-23150 5.36
13751-23160 5.38
13751-23170 5.40
13751-23180 5.42
13751-23190 5.44
13751-23200 5.46
13751-23210 5.48
13751-23220 5.50
13751-23230 5.52
13751-23240 5.54
13751-23250 5.56
13751-23260 5.58
13751-23270 5.60
13751-23280 5.62
13751-23290 5.64
13751-23300 5.66
13751-23310 5.68
Awesome guy for sharing!.
Albert
May 13, 2009
1,710
Tempe, AZ
They were the stock oem bolts, I figured they were long enough. It was the Hks cam gear being twice as thick. I really don't think it would of helped. If the threads for some reason didn't strip out the belt would of broken/jumped teeth.
14psi antilag on the car was fine. Did it all the time, I think once it was higher a big enough backfire relaxed the heavy duty springs I have, and with 272s it just said get get out of my house.
SideWinderGX;1900359 said:
$13 a piece will annoy you ;) I'm hesitant to measure all the lobes and order the buckets, and then find out I need one size larger/smaller...
I just Tipped/Sunk my Valves so I could order all the same ;)
(only took a couple of thou either way)
I ran the car very hard for a long time, no issue with adjustment and Crisp is still running it with the same buckets, mine hit 8300 every time I drove it.
(even having confidence in hitting the limiter while 1500Km's from home)
