My Rust-Free Project
iceberg319
vvti, what?
Apr 6, 2005
328
NJ
old and busted!
[thumb]http://i610.photobucket.com/albums/tt188/iceberg385/build%20pics/pic041.jpg[/thumb]
[thumb]http://i610.photobucket.com/albums/tt188/iceberg385/build%20pics/pic042.jpg[/thumb]
[thumb]http://i610.photobucket.com/albums/tt188/iceberg385/build%20pics/pic048.jpg[/thumb]
Interior:
[thumb]http://i610.photobucket.com/albums/tt188/iceberg385/build%20pics/pic051.jpg[/thumb]
[thumb]http://i610.photobucket.com/albums/tt188/iceberg385/build%20pics/pic052.jpg[/thumb]
engine:
yes i know its missing the fan shroud
[thumb]http://i610.photobucket.com/albums/tt188/iceberg385/build%20pics/pic050.jpg[/thumb]
black car specs (off the top of my head):
7M-GE
masterpower 61mm t4 .68 a/r
tubular manifold
tial 44mm wastegate
funkymonkey intake manifold
q45 tb
w58, act clutch, fidanza flywheel
ksport version RR coilovers
wilwood 6 piston bbk
energy suspension bushings all around
hks vpc, gcc, fcon, evc ez 2
denso 550cc injectors, walbro
b&m oil cooler
mocal oil thermostat
socketless oil lines
The new hotness:
[thumb]http://i610.photobucket.com/albums/tt188/iceberg385/build%20pics/pic035.jpg[/thumb]
[thumb]http://i610.photobucket.com/albums/tt188/iceberg385/build%20pics/pic037.jpg[/thumb]
[thumb]http://i610.photobucket.com/albums/tt188/iceberg385/build%20pics/pic038.jpg[/thumb]
What should i put in here? hehehe
[thumb]http://i610.photobucket.com/albums/tt188/iceberg385/build%20pics/pic039.jpg[/thumb]
[thumb]http://i610.photobucket.com/albums/tt188/iceberg385/build%20pics/pic058.jpg[/thumb]
[thumb]http://i610.photobucket.com/albums/tt188/iceberg385/build%20pics/pic059.jpg[/thumb]
The white car is a 89 and a very clean targa shell with virtually no rust. From what i heard it was an original Cali car, so probably never driven in snow. Most of the parts from the black car will be used to complete the white car (steering wheel, gram lights, abflug sides and rear and other little things). Things that wont make it to the white car will be the w58, bbk, and coilovers. Whether ill put the 7M in the white car or not will be decided last.
First stage of mods will be focused on the chassis and body.
I am in the process of removing the front and rear subframe. I have poly subframe bushings heading over from RonnieK :) The plan is to coat the subframes with Por15 and replace every suspension bushing with poly. If anyone has any tips it would be awesome
stay tuned for more updates
o yea! the red headed stepchild supra hehe
[thumb]http://i610.photobucket.com/albums/tt188/iceberg385/build%20pics/pic060.jpg[/thumb]
92nsx
2,957
Clearwater, MN
Clear sun shade, umm.... Well i guess it can't be called a sun shade since i dont think it will block much sun, lol.
Your black one didn't look that bad, but as always it is hard to tell from the pics.
GL
iceberg319
vvti, what?
Apr 6, 2005
328
NJ
the black car isnt that bad, its just the white car is so much better :)
the sunshade is either gonna be tinted or painted white to match the car, im not sure yet still deciding
iceberg319
vvti, what?
Apr 6, 2005
328
NJ
my cousin who im giving the black car to wants em so theyre staying with the car.
i have a set of mk4 rears sitting around, im thinking about fabbing up brackets so i can go with mk4 fronts and 350z track rotors. (my reasoning behind this is because the mk4 has fantastic brakes from the factory and theyre OEM too)
shaeff
Kurt is FTMFW x2!!!!
9
Around
To use the MKIV fronts, you'd likely have to use the MKIV front spindles. In doing so, the wheels will sit further toward the rear of the car in the wheel well. It looks like anus.
iceberg319
vvti, what?
Apr 6, 2005
328
NJ
what if i just made my own adapters, similar to the nightpager kit. i know its not gonna be a bolt-on affair. i can model it in PRO-e and give it to my machine shop
dubsupra209
CENCAL SUPRAS
Mar 6, 2009
1,810
Merced, CA
i love that black on gold its sexy...im planning on going white on gold if the funding is available..... :biglaugh:
iceberg319
vvti, what?
Apr 6, 2005
328
NJ
supra90turbo
shaeff is FTMFW!
32
MA, 01440
To reinforce the subframe, you should strengthen the areas where the differential bolts through. I'm at work and can't go into detail with paint and show you but if you look at it, it will make sense. Just get some steel plate and weld it to the subframe.
as far as that weight, I think it's a snubber for movement or a weight to drop down NVH....
OneJArpus
2,798
MK3.0dudeman;1403512 said:
Thanks for not calling me to help you take out the subframe ass hole.Call me later cause my phone broke and I lost my numbers.
Serious brian, calling him an asshole? LOL I had to install your exhaust cause you were scared to get under it, and you think your going to swap out a rear subframe? LOL =P!!!!
WTF CHRIS! I wanted your BBK! :(
GL NE way i'll be helping you one way or another :sarcasm:
OneJArpus
2,798
iceberg319;1404685 said:
brian no problem, when i get around to installing an air filter or gutting the car youll be the first one i call! heheh jkjk
or painting calipers or dying your interior =P maybe taking out your sound dampning =P
Just picking at ya brian don't catch a heart attack lol
