so, im replacing the compressor, dryer and expansion valve. flushing the lines/condenser the best i can with flush and 150psi air. cleaning the evap out and ill prob do the insulation wrap like mentioned. i have 2 e-fans pulling on the radiator, ill do the foam trick and see what happens.
questions i have, what pressures are yall seeing with these mods on 134? if my high side is still above what youre seeing ill do a pusher.
i do have a 608 but not sure if i want to spend the extra money when i can charge 134 for free, which leads me to question #2, how much more beneficial is r12 compared to 134a?
stupid question #1, how much oil should i put into the compressor and how much should i inject after a vacuum?
thankyou op, FINALLY somone on a forum that really knows ac.
and to the guy from iraq or whatever, assuming you were saying you retrofitted to an orifice tube but called it something else?
has anyone found a stronger blower motor? ill be pulling my dash eventually and check for leaking tubes but i dont get very good airflow, and ive never been in another mk3 to compare, heater/ac/recirc all seem about equally weak.
