motor locked on the stand????
Supra_Villan
needs his car done
Nov 10, 2007
662
Wellsville MO
i was turning my motor last night on the stand with my hands by the crank pulley it is fully assembled long block, but i was calibrating the cps, from 0-10* it turned relativly easily, but when i got much futher it got pretty hard, now the arrow on the crank pully is pointing right at about 5 o clock in the conterclockwise directions and i could not turn it anymore, so i figured i would sleep it off and be back tomorrow, whats wrong here? it was professionally assembled by a good machinist!!! :1zhelp::1zhelp::1zhelp:
supramk3man
414
kentucky
Was you just turning the motor by hand if so you might try getting a socket and try turning it. I'm not sure and i'm sure some will post for sure but it might just have made compression.
Supra_Villan
needs his car done
Nov 10, 2007
662
Wellsville MO
KicknAsphlt;1098083 said:
Do you have the spark plugs in the motor....? If so, take them out.
thanks for coming to my rescue :icon_bigg but i made the thread this morning, i had the recollection at work about this and took the liberty of punching myself in the face this morning...:eek:wned: thanks though guys
GrimJack;1098092 said:
what does qft. meant?
One more time for good measure ;)
Supra_Villan
needs his car done
Nov 10, 2007
662
Wellsville MO
Rennat;1098491 said:
you couldnt turn the motor with the plugs in though?
either...
man up nancy...
or double check everything is right.
not a nancy....
i could turn but once it got half way around and had built up compression i could go no further.
what all should be double checked?
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
Yeah... there might be something wrong, it is a low compression engine 8.5 to 1... it was almost fun.
A 7M-GE is hard to do by hand with something like 9.5+ to 1 but still not that hard.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
my first thoughts are the bearings being too tight, or the wrong torque on the connecting rod bolts.... cause my motor with spark plugs in wasnt that hard to turn... so im just sayin...
and maybe his version of 'locked' is totally different than mine... who knows. im not there to actually spin the motor.
btw... im speaking from personal experience, helped a friend rebuild his motor and he mixed up his rod caps...
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,966
DFW
Wow!!! You locked up your engine and it ain't even in the car. You're awesome. :biglaugh::sarcasm::icon_razz
bowsercake
828
Irvine, Ca
If the engine has been sitting for a long time then the oil/assembly lube on the crank/pistons might have deteriorated over time. If you still cant get it unstuck try relubricating everything.
Supra_Villan
needs his car done
Nov 10, 2007
662
Wellsville MO
well i took out the plugs and got a socket on the crank pulley bolt, it was rough for a little bit, but after that it strangely freed up like initally was at 0*-10* all the way around, not abnormally loose but i wasnt popping any blood vessels anymore
