MKIV Brake Rotors?
whudafux
Formerly dcrusupra
Jan 5, 2006
1,034
Cullowhee, NC
Supraforums said:
Night Pager kit, uses MKIV rotors and 300ZX calipers. the night pager kit is simply caliper adapters and rotor shims IIRC. the MKIV rotor fits on the hub if you take some material off the inside i think
you need a 2mm ring spacer to keep MK4 front rotors hubcentric on a MK3 front hub, that is, if what I've read and seen elsewhere is true.
do i get $100 now?
supra90turbo
shaeff is FTMFW!
MA, 01440
7MsAreForKids said:
You show me how the front rotors/calipers can fit and I'll paypal you $100
Nah, it wouldn't be worth all the effort just to prove a point. $100 wouldn't begin to reimburse me for the parts alone.
Just remember. Everything's possible.
drjonez
the motor city
www.4cefed.com
supra90turbo said:
Fronts *can* fit... but you have to put more effort into it than you did your search ;)
anything *can* fit.....just depends on how motivated you are to build proper brackets, etc.
i wouldn't call using MKIV spindles the best way either....you'll destroy your car's handling by doing so.
shaeff
Kurt is FTMFW x2!!!!
11
Around
not to mention it moves the tire further back in the wheelwell, and looks like complete ass...
-shaeff
jawsgear
Undergoing Construction
Jan 29, 2006
465
Sactown
www.jawsgear.com
I would like a picture if anyone has been able to make MKIV calipers work on a MKIII. Not just the rotors, but the rotor and caliper combination. Ain't happening, trust me after days of machining, grinding, and welding. For sure!
Never tried so I'll take your word on this ;)!
shaeff
11
Around
heh. check out 4cefed.com. and there was a pic around of someone's car with the mkiv setup on the front, too. it looked like an anus.
the rear brake/caliper install is relatively common now-a-days...
-shaeff
