MKIII Cruise Control
codster21
SD, CA
Can anybody help me out? I have an 86 mkIII with cruise control, everytime I turn it on, the dash light pops up but when i try to set the speed it doesnt work. can anybodu help me
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I've often found that the issue with malfunctioning CC is linked to out of adjustment switches on the clutch / brake pedals. I'd suggest checking those first.
Of course, I hope you're good at lying upside down on the drivers seat, with all the blood in your body rushing to your head, holding a penlight in your teeth.
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
I've found that dropping the seat back all the way, and moving your ass up to just on the top half of the seat, with feet in the back seat area works pretty well. This worked really well for me while installing my glove box/ECU. Your shoulders should lie right where you need it.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
LMAO!!! :biglaugh:
OR, you could just pull the seat and lie down normally. Put down a folder up blanket or a heavy jacket to lie on so the hump that's under the seat doesn't bother your back so much for the whopping two minutes you're down there. ;)
stolensupra
Gotta spray to play!
Jan 2, 2010
150
NORTH CAROLINA- Greensboro
What should you look for?
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Switches that are out of adjustment. For instance, my clutch switch had backed off just enough that it was always sending the clutch pedal is DOWN signal to the CC computer. It was a simple matter to reset the switch, and my CC started working again immediately.
