Meth Injection Q's
Ultimate CC
NY
You can install the nozzle anywhere from 6-12 inches but most prefer 6-8 inches. I install the nozzles a lot of times on the bottom side of the IC pipe and route the hose so that its hard to see and put wire loom over it for a stealth install...
tturnpaw
Supra Enthusiast
Feb 10, 2007
412
Everett, WA
IJ.;1229506 said:
You might want to check your history and see who was pushing the hardest for Metric way back ;)
Lmao you redefine old. If I needed this info you would be the first person to ask where it originated. It does sound contradictive though. :)
The metric system is the tool of the devil! My car gets forty rods to the hogshead and that's the way I likes it.
Turbo Drifter
534
Surrey, BC Canada
Anyone see any problem with running an AEM Water/Meth kit with direct port? or twin M7 nozzles pre TB?
I'm just a bit worried about good distribution of water/meth, I know direct is best but will the AEM kit work for this?
Thanks guys!
jz*supra
164
Lethbridge, Alberta
Jeremy i have the AEM kit and i don't see any reason why it would have an issue. The controller simply turns the pump on at XX boost and progressively increases to your max boost setting. It wouldnt not no if its running meth to 1 nozzle or 6. Only problem would be using oversized nozzles and pressure drop. the biggest AEM nozzle is 550CC, as long your nozzles are 100CC or less i can't see having an issue. Also i would use equal length hoses from the distribution block.
Has anyone ever ran into internal engine issues from long term use of meth? Your injecting water into your motor, some vapor has to make it into the crankcase and oil would it not?
For the guys running dirert port injection: Are you not worryd about the shutdown time of the nozzle? With fuel, pressure is constant and the injector is a valve that quickly opens/closes. When meth turns on it has to pressurize the line, opening the check valve at high pressure. When it turns off the excess meth on the engine side of the check valve slowly bleeds off and sometimes ends with a small drip. My check valve is inches from my injector to eliminate this issue, would 6 seperate hoses not cause a longer run on?
