MA70 OEM Suspension - Bushes, or Spherical Bearings?
ed_jza80
9
Sydney
Just a quick question...
THe MA70 standard suspension arms, upper and lower... are they spherical bearings, pushed into the control arm, and sealed (like the jza80) or are they actually a bush?
from jza80 land, theres alsways confusion about 'upgrading' the bushes to some poly bush, when infact the arms all run on pressed in spherical bearings (hence why a- toyota doesnt sell bushes, and b- the cunts are tough to get out should you try)
now the MA70 arms look VERY similar, and i note that toyota doesnt list bushes, olny complete replacement arms... logical step is to say they also run a sealed pressed bearing... not typical bushes.
can anyone confirm one way or another? please reply only if you *know* the answer. internet chinese whispers is bad enough already.
cheers
ed
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
IJ.;1758041 said:
Arms are all bushes
Rear upright has 1 spherical bearing the rest are bushes.
As usual, IJ is correct. Imagine the frustration not knowing this, pressing the bushing out of the rear knuckle to replace with the energy bushings, only to find out you reuse that 50 dollar dealer only item. Yes i was pissed.
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Considering that I had to buy new A70 upper arms because of worn bushings... Yeah. Plus the fact that although Toyota doesn't sell the bushings, Energy Suspension does. (Those kits became available less than a year after I bought new upper control arms.)
nctexan
268
Houston
Ok so is the location I've circled where the spherical bearing is located?
gwumpkus
76
Singapore, Singapore, Singapore
ths is timely post! i was at the workshop when my mechanics were wondering why my replacement PU bushings were short a pair (the one circled above!) so we swapped eveything else in, except for that one... so theres no aftermarket replacement for that piece? i've now got one "weak link" in each knuckle..:).. thanx again..
cheers
michael
nctexan
268
Houston
Ok to clear things up, I was ASKING if the item I circled in the detailed drawing was the bearing. You guys are taking it as though I was stating that it is the bearing. Can anyone confirm this is the case?
No it's one of the 2 marked "bushing" it's in fact a bearing, the circled hole is for the arm with the ball joint end on it.
Another important point when working on these is to NOT tighten any of the factory bushings until the cars weight is on the ground or you'll tear the centres out in a month or so.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
78
Atlanta
I assume we re all talking about the spherical bearing at the lower rearmost point on the hub.
Can anyone tell me the secret to removing this bearing, preferably on the car?
I tried using a 2 arm puller, but couldn't keep the puller stabilized. Do I need to remove the entire hub, and throw it on the shop press?
7mgte88
11
Maine
Wondering the same thing.... Girlfriend bought all new arms from Beech, that spherical bearing needs to go and be replaced with a bushing. ONLY because the other end of the Beech are is a spherical joint too.... I cant get that fucker out though. I had to cut almost all of the stock arms off.
jdc4357
56
missouri
I doubt you can get it out while on the car. I bought a 20 ton harbor freight press ($150 bucks with coupon) for this project and it took alot to squeeze one of those sob out. Also, you might as well take them all out, as a couple of mine were shot with 160k miles on them.
destrux
1,183
10
PA
The easy way to remove the stock spherical bearing/bushing on the rear without pulling the knuckle off is to use a socket and an air chisel with a flat round bit. It comes out like butter. Took me about 15 seconds per side.
Then to install you just need a few washers, a socket, and a long bolt or threaded rod.... and you use the rod/bolt through the middle to pull it into the knuckle. Easy.
Thankfully the "torque it at ride level" only applies to the factory bushings, not the energy bushings (they aren't bonded to the sleeve like the OEM bushings). One of the reasons I like the energy kit... much easier to torque stuff with the wheel off in the air.
nctexan
268
Houston
Ok, so then my diagram should look as follows:
Is this correct?
jdc4357
56
missouri
You have them switched. The green text is where the poly bushing goes, the red text with light circle is where the spherical bearing goes.
Grandavi
2,664
8
Calgary, Alberta, Canada
The TSRM has a line from the Bushing to the "light (thin) red circle" suggesting a bushing. The only one with no bushing with a line going to it is the thick red circle.. is the TSRM incorrect? lol
I can see how doing it yourself could get confusing.
jnybbad
61
vacaville, ca
I know this is old but the energy suspension kit I just got comes with poly bushing to replace that spherical one. Is there any benefits to using it?
Backlash2032
1,823
Nebraska
Can anyone confirm this? I'm doing bushings in a week or so and would prefer to only do it once lol
