Le Bella
rwdanthony
146
San Diego
87 supra, 7mgte, r154, sport package (lsd, no tems, abs) 61k miles.
Full build up for general fun and drifting.
I started this build around jan '11, so most of this post is back tracking. anything after this is current.
engine:
HKS 1.2mm headgasket
ARP studs
ACL main, rod, thrust bearings
NPR piston rings
57 trim ct26 Polished compressor housing, ceramic coated turbine housing
FMIC & aluminum piping
Synapse Synchronic BOV
Synapse anti stall kit
NGK ignition wires
Denso MDL560P injectors
EV1 injector pigtails
Denso 195130-1270 280lph fuel pump
lexus 1uzfe maf
yada, yada, yada
EV1 pigtails being soldered in and fuel upgrades
got the original mounts welded, dont see the point in buying solid ones when i could just do this.
currently on hold:
rebuilt the transmission before it went in got a bunch of nice goodies while i was at it.
action stage 3 6 puck clutch disk & pressure plate
full length SS clutch line
Maxgrip lsd kit
4.30 lsd
rebuilt my work equips and ended up with
18x10.5-12
18x11.5-26
225/40/18 f
255/35/18 r
suspension components:
part shop max competition coilovers
battle version rear camber arms
battle version rear traction arms
shortened toe arms
SuperNow outer tie rod ends & steering rack spacers
Power Slot rotors front & rear
EBC red suff brake pads
dropped the rear end so doing a couple of things
solid rear subframe risers
shaved unnecessary brackets and studs, not sure if i want/need to brace it.
lowness
exterior:
s2 authentic rear fenders
part shop max hood risers
jdm kouki tail lights
jdm sidemarkers
euro signals
kouki side mirrors
kouki front bumper
xzeror
1,356
Miramar, FL
sick x.x, what size and offset were ur equips originally and how much did the rebarrel cost/where did u buy it at? Just need some paint to be complete now :)
rwdanthony
146
San Diego
boostmaster21;1795869 said:
sick build wheel fitment is not the usual but that makes it 2x as interesting.. im intune with this one
thanks!
i had a set of:
18x10-3
18x11-4
18x13-7
final set i made was:
18x10.5-12
18x11.5-26
sold the extra pair
i did all the barrel work myself.
Dizzy562;1795876 said:
Looking forward to how this one comes out. Will you be bringing this out to some of the SoCal Supras meets this year?
maybe
Crashoveride;1795911 said:
a1904thing;1795933 said:
Nice one!
planemos;1795971 said:
Now that right there is done correct!
thanks guys
not much updates today, drilled another set of holes in my stock sway bars for adjustability, probably only be putting the rear as stiffer since it understeers as it is for me. then dropped off the rear subframe with the sway bars for powdercoat
got an extra pair of knuckles to be cut for more steering angle
finished the LSD
energy suspension sway bar bushings. NOTE* energy suspensions database for our cars is incorrect.
factory sway bar diameters:
F - 27.2mm
R - 21mm
energy suspension database/catalog:
F - 27mm (8.5133)
R - 23mm (8.5134)
Though the front is .2mm small, it still works. only issued i encountered with it is that the overall height was 2.5mm too tall so i trimmed the bottom. rears i had to return and buy the universal kit, product number 9.5125.
i bought these from: http://www.energysuspensionparts.com/
The whole hassle with their database being wrong and for me to be the one losing the money on shipping is really unsatisfactory customer service, i think.
mkiiichip
1,434
WI
Man you have taken your car a long way in just a year. Well done.
What do you think of the maxgrip kit?
rwdanthony
146
San Diego
Yeah i cant believe its only been a year. Thanks!
So far I cant give it any feedback since i haven't driven it yet. Looks promising though.
rtrdpenguin;1796086 said:
So I ended up not going with the ford mixture marco.. I was looking at this brand called sta-lube, and then I saw lucas.
So far the diff is completely done. I dropped off my extra knuckles to be shortened, and toe rods at pbm, hopefully they can make us some toe rods...
I'm still waiting on my rear subframe and sway bars to be done at the powder coaters.
I also ordered energy suspension bushings for the rear end, and those should be coming in soon. im probably only going to be using a third of the kit since all my lower arms are going to be replaced with hiem joints.
Lastly I made some sway bar end links. My rear sway bars rubbed my axles, so I might have to make it longer than factory just to clear better, or do something else... I still have to make the fronts, which I believe I have room to make them shorter so the sway bars can be closer to parallel with the ground.
bhmsupra
529
It's Not Important Bro
Awesome Work. Those S2 Rears are just awesome. Match the OEM fronts so much better. I wish Toyota had done that from the factory.
What site still carries the S2 rears? is it RHDJAPAN?
rwdanthony
146
San Diego
pretty much
