knock sensor question
soupersupra
71
Spokane, WA
i have a 87 7mge and i am not sure if the turbo knock sensor is the same as the n/a sensor... i put it in and it works and cleared the code but not sure if my problems i have right now are because of that sensor...
the problems~ pretty sure they all relate
~ the exhaust is popping on downshifting and when cruising where im not accellerating or decellerating, im in between i kinda get this miss sorta thing, with a slight surge kinda like the car cant make up its mind whether it wants to speed up or slow down... on accelleration it runs great
~ and it starts up kinda slow in the morning with a miss for about 5 seconds
~ i just did the head gasket injectors are clean and fuel rail is clean...
any ideas?
thanks
AJ'S 88NA
2,419
Florida
any ideas?
thanks
Have you put a timing light on it? Checked the TPS to make sure it is aet right?
soupersupra
71
Spokane, WA
timing is right... ill check the tps... and after i did head gasket i started getting bad gas mileage too its odd
