Jonah 91 white package
jonahs_supra
1,015
Lancaster, Ohio, United States
So my head is almost done
Getting the following:
Milled
Wicked port job(by a friend with 1k hp 2j who built his motor lol)
3 angle exhaust cut
5 angle intake cut
Comp cam valve springs(BBC inner springs)
jonahs_supra
1,015
BoostMonger;1891132 said:
Can I have? I made a mess in my pants
Why yes you can. For a price :)
It started out as a simple valve job, mill and reshim.
He has since decided he wants to do some major work on porting it.
He estimates 80-100hrs in it just for porting lol.
Now i may have to go for more hp :)
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
AbsoluteSpeed;1900346 said:
What happened to the Titan HG and ARP’s?
SBM713;1900710 said:
why not go mhg just curious?
Metal Head Gaskets REQUIRE the block to be machined. If you replace a head gasket with an MHG and you dont machine the block you're going to have another BHG.
MHG = Machined Block. Every. Single. Time.
This is one of my pet peeves of the mk3 community. Other communities, namely the 4 cylinder crowds can get away with it more easily. With the long sealing surface of an inline 6 it's prone to problems. The makers of all the MHG's specifically say you MUST have an RA below XX which you will only get with incredibly skilled lapping work or machining the block deck.
If you can't get the block machined, DO NOT USE AN MHG. :)
AbsoluteSpeed
735
Edmonton AB
I realize that. Somehow I thought he had done a complete rebuild.
In that case, good move sticking with the OE gasket.
jonahs_supra
1,015
Thanks rx7nut for explaining my choice.
I don't want to pull a motor for a metal head gasket if I'm going to be keeping a stock bottom end for now with no extra money for a rebuild.
If it blows again then I will replace it until I'm ready for a complete rebuild
I will say the headwork that I got done. Really helped with low end torque
Still need to update with pics
Also suppose to be getting another auto trans with low miles.
In which I will have valve body modified and shimmed accumulators
jonahs_supra
1,015
jonahs_supra
1,015
Ok so here are some update pics
My billet cps cover that i polished up:
My turn signals that i polished up:
My n/a valve cover that i polished up(will be installed once i get jz coils and possible ffim)
Now for assembly. My fan shroud was cracked and would cause harm if it broke so i kept it off til i buy new. Mounted air filter so it wouldnt hit fan blades
