J-tube bypass?
DGmk3
DomesticMan sucks
May 15, 2006
122
Superior WI/(Duluth MN)
I'm gonna be installing a AFPR and I've heard that I should bypass the jtube can I just bypass it or does it have to be removed and blocked off???
supra90turbo
shaeff is FTMFW!
32
MA, 01440
kwnate
Lurker
Jul 10, 2005
2,725
None of your fucking business
Why do you need to remove it? I thought if you bypass it you can just leave it or grind the tube off if you're too cheap to buy a block off plate?
edit, read kurts post again... I read it wrong. God I'm such a moron, Fuck...
Racefiend
OH, YEAAHH!
Apr 6, 2005
106
Bay Area, CA
^^^You are correct. You can do whatever you want with it. Heck, get yourself a 5M oil pump driveshaft, and slap a mechanical fuel pump in there if ya want :)
Allan_MA70
1,055
Melbourne, Australia
drill it then piss of the tangled snake steel line.. too
done!
theDon
The Don
Med-City, USA (Rochester, MN)
it's just part of the fuel line and has a restriction in it by design. For more flow people bypass it, then you can remove it and get a block off for the block or leave it there for decoration :)
shaeff
Kurt is FTMFW x2!!!!
11
Around
the j tube is there incase the stock fuel pressure regulator craps out. the restriciton in the j tube will cause enough backpressure to maintaing fuel pressure so you could limp home. with high flow pumps, the restriction is TOO much, and causes fuel pressure issues. (ie: too much pressure= running really rich)
-shaeff
theDon
The Don
one end is fully open, the other end has like a pin-hole opening - that is the restriction for backpressure.
Do a search on J-tube and you'll get some shots I'm sure, I just saw one recently...
shaeff
11
Around
here's a good shot. see the tiny hole? that's the restriction-
edit: YES, it's a HUGE pic!
-shaeff
