Im in that position to plumb my water and oil lines for the turbo... I know there are alot of you gus running DBB and/or oil & water cooled turbos... Im trying to figure out what fittings I need to go directly from the block for oil feed and the water neck for water... And what size fittings I need to attach to the turbo for the water... I already have my turbo's oil fittings, a 4AN for the feed and a 10AN for the drain... I've searched and found no write ups on this and people have tried explaining what I need, but if anyone would mind posting part numbers and diagrams and even pictures, I would really appreciate it... Im also looking for a write up on fuel lines to tap AN fittings directly to the fuel line... I want to dispose of all my "eye bolt" fittings...
Thanks guys...
Jake
Thanks guys...
Jake
