HUGE oil pressure problem, think I found the cause??
PorterzSupra
703
Hebron CT
Okay basically I had a HUGE oil pressure problem and I was running 85+ PSI I thought it was because I shimmed the oil pump 8 mm but now I think thats not what the problem was, I think I just found it. I am doing a NA-T in a turbo car so I have a NA block and I was using the turbo oil pump/attachments and I just realized in the turbo setup they have 2 lines connected, the pickup and another line out but on the NA it is blocked off and not used on the side so I think the pump was sending pressure thru the tube out to the block where it was blocked off, I think maybe in the NA your not suppose to connect that line since its blocked off its suppose to be open so it can just dump into the pan because in the turbo you use that line. Is this correct, was this the oil pressure problem? I think maybe im not suppose to use that line at all when using the pump in a NA you leave the thread open? Also can somone set the record stright with the correct oil pump shim in mm because I have herd so many different things I dont know what to go with, does everyone agree with 5mm?
Attached are the pics, let me know if im right!!
You really don't have a clue do you?
All 7M's have the hardlines you describe.
The external port you're pointing at is the NA Hot Climate Oil Cooler Port.
None of this has anything to do with your over pressure problem that is all down to your Gump Shim......
4.8mm of shim is plenty due to the springs short length any more and you run the risk of coil bind and the relief not relieving and blowing the O-Ring out of the Oil Filter.
Didn't you trust me the last time I posted this or that I PM'd Shaeff and he added the info in bold in his sticky?
supra90turbo
shaeff is FTMFW!
MA, 01440
ok... i'll do something worthwile...
You didn't listen when we said not to use a cork oil pan gasket.
You didn't listen when we said not to shim the pump out till the spring binds.
You didn't listen when we told you how to route the oil lines.
What makes you think you're gonna listen now?
Nice Fram oil filter btw.
whudafux
Formerly dcrusupra
Jan 5, 2006
1,034
Cullowhee, NC
supra90turbo said:
Let's not go through this again!
look at this instead!
for some reason i felt a sharp feeling in my nuts when i saw this. Maybe its because he's sitting on a freakin hedgehog. But I must admit, he has a cool hat.
PorterzSupra
703
Hebron CT
ummm that line is not used, therefore it does not need to be connected, its just blocked off. Why would a line need to be connected when it does not do anything, if that wasent the problem what was, because ppl on here say they have run 7mm shim without a problem I ran 8 and had huge problems.... wtf is going on then im gonna take the line off anyway because im not using it.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Its has been stated here before. All supras are different, Put some faith in Ian as he is not trying to mislead you, he is trying to help you. 4.8mm OR LESS!!! Why, cuz he is a fart smucker...;)
I agree the other thread was tad misleading. But the point of it was to explain that there was some bad information out there and that coil bind was a bad thing.
Edited: due to the sarcasim thats coming, Do not bybass the hard line...
Jimi87T
1,127
4
Colorado Springs
So let me get this straight, you are going to run the oil pump by letting the hard line just dump back into the pan.........so all you will end up doing is pumping oil back into the pan, and no oil going into the motor..........I say go for it, what the heck, you've done such ground breaking things so for, why stop now! Supras don't need oil anyway, it's just added weight.
wingman
sucka got blammed!
Sep 11, 2005
427
Phoenix, AZ
hrm...ghetto oil bypass kit
guess I won't need to pay an arm and a leg from KaleCoAuto now
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Keep looking.. It's called an outlet pipe for a reason...There is only one outlet on the oil pump that supplies oil to the block. That is it...
PorterzSupra
703
Hebron CT
ahhhh... point taken. im gonna shim 4 mm try again with a new pump, hopefully this time I wont blow out my turbo seals and run 85+ PSI
