Okay basically I had a HUGE oil pressure problem and I was running 85+ PSI I thought it was because I shimmed the oil pump 8 mm but now I think thats not what the problem was, I think I just found it. I am doing a NA-T in a turbo car so I have a NA block and I was using the turbo oil pump/attachments and I just realized in the turbo setup they have 2 lines connected, the pickup and another line out but on the NA it is blocked off and not used on the side so I think the pump was sending pressure thru the tube out to the block where it was blocked off, I think maybe in the NA your not suppose to connect that line since its blocked off its suppose to be open so it can just dump into the pan because in the turbo you use that line. Is this correct, was this the oil pressure problem? I think maybe im not suppose to use that line at all when using the pump in a NA you leave the thread open? Also can somone set the record stright with the correct oil pump shim in mm because I have herd so many different things I dont know what to go with, does everyone agree with 5mm?
Attached are the pics, let me know if im right!!
