How would you get the heat out of your Supra?
ViR2
Supraniac
May 20, 2006
932
Lithuania
www.hpaddict.eu
turbo blanket, adjusted valves (yes, they emit a lot of heat if they dont shut or open properly), heat insulating the downpipe, aluminum radiator... Thats from top of my mind :)
HommerSimpson
1,067
New Smyrna Beach Florida
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
Don't remove the rubber seal unless you want to be running on 5 cylinders after every rainstorm and smell every little thing in your engine bay. The best way to manage heat is by insulating the downpipe, exhaust manifold, and turbo, as well as keeping the exhaust manifold heat shields in place. Other more creative ways include fabricating heat shields to isolate the exhaust manifold and turbo from nearby components (ABS, intake, etc)
QWIKSTRIKE
475rwhp459torq an climbin
Apr 3, 2005
1,172
Some where out there
Great answer.....ask me how I know;). Now that said get a vented hood, and a turbo blanket. See my hoood in my avatar......it let's out tons of heat.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
I learned this from experience as well....
MKIIINA
Destroyer of Turbos
Plano, TX
turbo blanket helped my underhood temps alot! ceramic coating on the manifold and dp will help a whole lot.
another "minor" detail is, clean the engine! a dirty engine (covered in grease, oil, brake fluid, and Lord knows what else) is hotter than one thats cleaned up.
spoolint78
Representing T.O
T.O
^^^ think that would have the same effect as removing the rubber seal.
I removed mine, and put it back on immediately
figgie
Twin Cities, Minnesot-ah
john93t;1060643 said:
remove the rubber seal between the bulkhead and hood
daledoe;1060890 said:
Put washers under the hood bracket it raise the back of the hood
Nope, Adam is correct :)
JesseH
1,153
to keep mine cooler Ive got the exhaust manifold, exhaust housing, and the downpipe ceramic coated, Ive also go two electric fans infront of the radiator where the AC condensor used to be for the extra hot days or when im beating on it.
626na
143
cali
so the washers dont work, also why did u put it back on?
can i please see the stock engine cover thingy
