How much Boost safely?
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Just wondering what the most amout of boost I can run safely? Mods
• 550 cc Nippon Denso fuel injectors (cleaned and flow balanced)
• Lexus V8 airflow meter
• New Toyota MKIV Twin Turbo (Denso) fuel pump
• Aeromotive Adjustable fuel pressure regulator kit with stainless lines & fuel pressure gauge
• 60-1 by Perfomance Techniques
• Porsche-spec Bosch blow off valve
• Satin black ceramic-coated Defcon exhaust downpipe with bung for wideband probe
• Apexi S-AFC fuel computer
• SSQV
• .017” Ross pistons
• New Spec Stage II Kevlar clutch
• 1.4 MM Cometic metal headgasket
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Fletch, Im with Cryo, 18psi... 20 at the most... Let your tuner tell you where to stop... Put it on a dyno, and tune it...
racingtoyota007 said:
not to get off topic but how much can the stock block take as daily driven?
Its not the block you have to worry about, its the pistons and rings...
If you have a good tune and enough fuel and keep it out of detonation you're pretty damn safe on the Ross pistons!
I ran 25 daily with an occasional spike to 32psi without any sign of distress on the pistons! (They're FAT and tough!)
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
25 on a stock ct? 60-1 ct?
racingtoyota007: you'll be fine on 12psi...
