Hid's ?
JDMMA70
2,550
Houston
supraman666;1288017 said:
just like that exactly. i was just sayin i have the ebay lights and still had that line and that even with the hight beams on the light wasnt all over the place. i will find out tonight how many people i blind when i go for a ride.
I want pics for proof of this ive never seen eBay lamps provide even a decent cut off.
taken from an old thread.
eBay Housing Left Hella E Codes Right both fitted with HID's
and mine before i lowered the lamps a little they were out of alignment anyways beforehand
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
becauseican;1288024 said:
I mounted my ballasts on top of the front bumper support undernieth the the header panel.
+1
Same place where I mounted mine on the backside of the front bumper most all good ballest are water proof but not safe to submerge.
As close to the light as passible yet as high & dry I found the front bumper above the foglight and below the head light is the safest area to mount them.
shaeff
Kurt is FTMFW x2!!!!
11
Around
Then I rest my case. If your cutoff doesn't look like this:
or very close to it, then you have no argument.
You see all that scattered light above your "cutoff"? Yeah, that's blinding oncoming traffic...
Mo87NA
1987 7M-GE & 1991 7M-GTE
8
Upstate NY
[thumb]http://i29.photobucket.com/albums/c295/shaeff/fx35ouptut.jpg[/thumb]
:withstupi
5
Wish I could find one of my old DOT halogens (think I tossed em)
DOT sends more blinding light than E-code lenses with my HID's.
Keep in mind my HID's didn't last long and I won't be buying them again and instead replacing all the lighting (headlights and fogs) sometime in the future...
A70BoosTFienD
A.K.A. Knight Rider
Oct 28, 2008
224
Orlando, Florida, United States
Agreed. but thats in a bmw.... has anyone made it look like that like that in a supra? whos got as pic of the retrofit?
shaeff
11
Around
Good eye. ;) However, that is NOT stock lighting for that particular model, an e36 M3. If I remember correctly, that's an fx35 retrofit using blacked out shields and TSX lenses.
Yes, the very same setup I mentioned above in this very thread. And it's been done to a Supra before, although this is straight fx35:
http://www.supramania.com/forums/showpost.php?p=1224574&postcount=21
I've got two sets of fx's at my house. One's going in my M3, the other is going in my GF's '99 Legacy. I'll be getting another set for a crazy idea I've got bouncing around my head for the Supra. And if anyone is wondering why I love fx35 HID's so much, it's because they're very compact so they're easy for retrofits, and they're bixenon, and I enjoy my high beams, especially where I live!
supraman666
124
PAWTUCKET RI
wow calm down dude . you want proof ill take some pics and post them for you. and how the hell am i suposed to get cutoff like a projector light from a hallogen type enclosure. if you were trying to put me in my place you should have gotten a picture more suited for the situation.
shaeff
11
Around
You're not, and that's my point. Putting HID's in a housing designed for a halogen is stupid. Been there, done that. However, I learn from my mistakes. ;)
The picture I posted is suited EXACTLY to the situation. It's a PROPER HID retrofit using Infiniti FX35 bixenon projectors in euro ellipsoid e36 BMW housings.
My point is that instead of putting HID's in a halogen housing, you should be retrofitting HID projectors into whatever housings you choose. I'm not trying to put you in your place, I'm trying to educate you. There's a big difference.:3d_frown:
Oct 11, 2005
3,822
27
Thousand Oaks, CA
Following up on the FX35 HIDs... In the attached photo of some 07 FX35 HIDs, the wiring shown does not look hi-voltage. Are these missing parts... like maybe the bulb and ballast?
Never mind... I think I've answered my own questions with this picture...
JDMMA70
2,550
Houston
In for pics
shaeff
11
Around
[thumb]http://img10.imageshack.us/img10/8915/dsc00660l.jpg[/thumb]
[thumb]http://img509.imageshack.us/img509/9255/35f11.jpg[/thumb]
Yep, you answered your own question. The red wires are for the HI/LO solenoid. The connector that goes before that has a diode in it from one wire to the other. Many people run them with no diode just fine. I have the pigtails w/ diodes in them. In the first pic there are also no bulbs. (D2S)
The second pic shows the high voltage wires and OEM Infiniti/Nissan Matsushita ballasts. The ignitors are attached directly to the back of the D2S bulbs in pic #2. They make a "long wire" and "short wire" version of these ballasts, but you can buy the wires separately and swap them out easily. :)
If you're interested in how to modify the FX's for a sharper cutoff than OEM can provide, cut off the second shield, black them out, and run the clear lens version, not to be confused with the frosted or fresnel versions, which provide a fuzzy cutoff, even with the shield mod. I've got some pics up in my M3 thread. Pics here: http://www.supramania.com/forums/showpost.php?p=1230632&postcount=74
and here: http://www.supramania.com/forums/showpost.php?p=1230633&postcount=75
lilazni3uoy
AEM Powered
NoRCaL and SoCaL
you guys should just listen to Shaeff, he knows what he is doing and what advice he is giving out and, he did bring up pictures of my car, with fx35 hid projectors bulbs and ballast, i've had this retrofitted in 2005, there is only a handful of mk3 owners that have done, you will never get a cutoff like you do with a HID PROJECTOR vs the hella 200mm ecode ece housings, with pnp hids. THE FX35 projectors are the smallest you can fit, WITHOUT cutting up your radiator supprt like other guys do with their flush mount projectors, and nsx headlights. I used the Fx projectors because for what it is, it's very intense, they aren't as wide as a tsx, tl or s2k projector but it works, i've been using this setup for almost 5 years now and no complaints. I had to do minimum cutting to fit it in my headlights
SC Rydah
86
New Jersey
Shaeff "educated" me once. Not mad at you bro. I will look into it when I get the money...and the parts. But as for your question about mounting the ballasts:
I took my lights out, looked at the opening real good, and the brackets (which fitted loose around the ballast) and just decided to zip tie them to back of the bumper support - like a few other guys. There's some holes (one small, one big) in the support where you'll put the ties through. A good light (headband light) will be your best friend right now.
Get some nice sized ties if your bracket dosen't hold it well, (use two on each if you have to) and they'll hold fine. They got a little wet in the snow, but that's about it. Unless you run into a big puddle or something, They won't get soaked.
shaeff
11
Around
supra_holic2002;1301922 said:
Here is a crazy idea that has been on my mind for a while..... for the people that have done the fx35 mod --- can u do the low pro mod
here--->http://www.supramania.com/forums/showthread.php?t=18406 and put the fx35 projector in the 3x6 light? is there enough space to put it without serious cutting?
[thumb]http://www.echowavepro.com/Supraphotos/Headlight/Untitled-80.jpg[/thumb]
[thumb]http://www.echowavepro.com/Supraphotos/Headlight/Untitled-24.jpg[/thumb]
That would look so aggressive:naughty:
Meh, that conversion doesn't do it for me. In my opinion, the best looking low profile setup is the NSX popups. When done properly, they look like they belong on the car. I'm trying to figure out a way to use the FX projectors in the NSX lights cut to a shallower depth to avoid cutting the core support.
LOL, good. Even if I come across as a bit harsh, I mean it in the best of ways. :icon_razz
SC Rydah
86
New Jersey
I know bro! that's why I'm on this forum. You guys can tell me stuff I NEVER WOULDA KNOWN otherwise. But you know what Shaeff? That NSX popup idea is the best idea i've heard for our cars besides flush mounts! They look good, have hi and lo beams seperate, and WOULD look good on Supras, they look almost like Ferrari Testarossa flip-ups imo. And we ALL know THEY look real good.
