Poodles;1439561 said:Band-aids, lots of them LOL
It's not something I would do unless I HAD to do it (I HAD to as the EGR cooler was leaking and trying to melt my wiring harness).
no, by blocking off the EGR ports and leaving the cooler all you doing is leaving hot gas trapped on the back of the head. JDM cars didn't come with a cooler, instead they had a two bolt plate to cover the hole of the cooler.roadboy;1439662 said:do you have to have a EGR cooler if you blocked off the egr ports?
Poodles;1439856 said:Remove 3 bolts holding tranny mount to crossmember, lift tranny to tilt engine forward.
Poodles;1439999 said:No adjustment in the hood![]()
