Heavy MKIII vs S2000
jugodegolf
Phoenix,AZ, United States
About a 1000 weight difference, very close race from 30, beat me by a hair. :naughty:
Guy was cool, his car was about '01 and still beautiful. He said he only had it for about a month. :nono:
Yblegal91t
it finally runs!
Apr 22, 2006
331
C1 outer
id say definitely the 7m.
i actually did race one from a stop and just took him by a car at about 60 with my 7m that had intake, exhaust and mbc
oh forgot to mention on an old tired a340
trydrew
Suprafied
Nov 4, 2005
1,038
Earth
Raced one a while back on the highway, his passenger caught it on video apparently. It was a 50ish roll iirc. I started to pull on him a bit, and would have kept on, but we ran outta room. I don't remember what we ended up backing off at.
http://videos.streetfire.net/video/S2k-vs-old-school-7m-1jz_208960.htm
Rebuilt 7M with 2mm cometic (slightly lower compression), ebc 12lbs dying stock ct, 3in exhaust, intake.
He had exhaust, and intake.
Honestly I was disappointed I didn't pull on him more.
1000th post!
91TURBOSUPRA
424
ct
that 2j should of left that s2000 by bus lengths ...... i would think that honda was pretty worked.....i raced my friend with his supercharged s2000 with my 2j and left him by a good 4 cars.... my car is on stock twins with the wastegate hose pulled and microtech standalone
frontierguy25
968
TX
Poodles;1338372 said:
His is a stock JDM 2J swap with an auto...
In a MK4 that is a low 13 sec car even with an auto, now in a MK3 a high 13 sec. S2000 run high 13's so it would've been a good race.
jugodegolf
Poodle is right. The reason is more likely my exhaust setup.
to start it's a 3'' downpipe courtesy of SC. then for who knows why they attached/left it 2 1/2" the rest of the way. I've taken it in 3 times now to quiet it down. First 2 times adding resonators, 3rd to swap mufflers. I couldn't stand the loud drone.
One day the car will be fast, just not in the near future.
jugodegolf
At what boost? I'm sure the 2jz car could be made a lot faster. Frankly it's just too dependable for me to change anything right now. I've had to put nothing but oil, brakes and tires (well the was the track incident) on it since 05.
91TURBOSUPRA
424
ct
21-22 psi its on a r154.... tuned to run that boost by chevyeater......... with a 3in exhaust, fmic w/ 3 in piping, and its on us spec stock twins
Tough loss George. Did you try brake boosting? Not that it would have helped much since your turbo's come on pretty quick anyways. S2000's aren't much more than go karts with air conditioning. They're just a bit lighter than your car and I'm sure you were bigger than he was. I doubt you'd even fit comfortably in an S200000000000000.
How's the '92 running?
jugodegolf
Yeah. I need to make it more worthy...eventually. After riding in Mariano's I have my goal for it.
92 still haven't cranked her yet. Will give you a call.
Justin727
T-virus infected
correct but agian george's car is a JDM 2jz not usdm..
George did you ever swap everything over to the usdm stuff yet? Cams, ecu, injectors, pump.?
