hanging plug???
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
ok i was working on my 86.5 5spd while i was working on the brakes ont the drivers side i noticed a plug hanging out from under the car it goes up under the intake mani somewhere cant tell where but the car is running but really rough sputters alot. and also where does the vacuum nipple on the intake mani run too?
johnathan1
Supra =
Aug 19, 2005
5,056
as far as the plug, i don't think anyone will be able to help without a pic...
the vacuum nipple, is it the one facing the firewall? because i believe that one goes inline with the vacuum to the cruise control, using a "t" connector?
shaeff
Kurt is FTMFW x2!!!!
11
Around
if your car is running rough, it might be a knock sensor connector...
-shaeff
JesseH
1,153
If the clip is red, its probably the fpr vsv
edit: does it look like this???
walka
46
beltsville, MD
does it looook like this wire?? :p
recently doing my head gasket..i couldnt figure out where this one went so i was told to just leave it alone ....
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
it has two wires only. one is red the other is yellow,and it runs to the lower part of the intake mani. ill see if i can borrow my friends camera and post some pics.
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
thats gotta be it mine arent working. ill try to hook it up as soon as i get the time thanks and ill let you know if thats it.
