GTEpower.com/GTE powered engines with 500+ RWHP site coming soon/sort of...
Status
Not open for further replies.
gixxer750
2jzget comingsoon!
Mississippi
I think it should be double whatever the particular gte engine made stock.....
That would be 460 for a 7m, 600 for a 2jz, 400ish for a 3s.... and so on.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
So we agree then:
230hp x2 = 460hp (crank)
460hp - 15% (drivetrain loss) = 391 wheel hp.
Rounded up makes 400 whp :biglaugh:
bfr1992t
The quiet one
Oct 29, 2005
272
Ohio
MKIIINA said:
lol one of the reasons we did 400 rather than 500 was because 400 is 58% improvement over stock for the 7M. yes the 2j comes stock higher but this is how we balance it out. plus i dont care about some guy who did 500 one time on a dyno on race gas but putts around daily on low boost at 350. we may change things up later on for 500rwhp or make it a sub section but currently its 400rwhp.
530 rwhp was easy to me - first try on the dyno.
Yes, I "putt around on low boost" over...400 rwhp. Lower if I'm tired or in traffic, etc because I simply don't need/can't use all of that power on the street anyways. Funny the above comments coming from an n/a owner? Have you driven a 500rwhp car? Not knocking you but it's not always easy to control. :)
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
bigaaron said:
With nice 275 tires on 10" wheels it should not be hard to control at all :biglaugh:
Full throttle and countersteer that biatch!
LMFAO!:biglaugh: :biglaugh: :biglaugh:
shaeff
Kurt is FTMFW x2!!!!
11
Around
if it's 400hp, it should DEFINATELY be RWHP. hell, i'm at 340hp on the stock turbo and it's got chipped impeller blades and shaft play! (289rwhp/295ft lb tq)
it HAS to be rwhp. i think 475rwhp is a good goal. :)
-shaeff
edit: wow, i must have been drunk writing that^ heh, i'm definately not at 400+ on the stock turbo. shaeff+ tired = shaeff FTL.
cjpp78
68
lavonia GA
I think 450 is a good number. requires a little work and wouldnt be so easy for the average bpu MKIV and upgraded ct26 MKIII. I think there is a lot less cars with 450 than with 400rwhp. Impressive power but not to dam hard to get, 450 is good starting point for the site.
Status
