Furious But Lazy 7M owner who gave Up.
ThunderZTA
Twitch
Apr 17, 2012
75
Texas
Turbo Habanero;1884500 said:
Where can I get a spacer?
Andy does them:
Turbo Spacer/Flanges
These Are Turbo Spacers And Can Be Tapped So It Can Be Used As A Flange.
Shipping: $6.00
Specs:
-Can Be Made In 3/8", 1/2", 5/8" And 1" Thickness
-Can Be Tapped To Any Thread Pitch Of Your Choice To Be Used As A Manifold Flange
-Flanges Are Made Out Of Cold Role Steel But Can Be Made Out Of Stainless Steel
Price:
T2 3/8" Flange - $30 Stainless Steel - $45
T3 1/2" Flange - $45 Stainless Steel - $65
T3 5/8" Flange - $65 Stainless Steel - $75
T4 1/2" Flange - $55 Stainless Steel - $65
T4 5/8" Flange - $65 Stainless Steel - $80
T4 3/4" Flange - $75 Stainless Steel - $110
T4 1" Flange - $85 Stainless Steel - $145
Turbo Habanero
4,229
Tucson,AZ
How much cranking should it take before I see oil pressure?
We have been cranking for about 10min with no efi fuse and oil has not reached the filter or turbo lines.
Leave em out....
You don't want cylinder pressure Splooging out the assembly lube from the bearings.
If they installed the pump dry it'll take a fast spin to create enough suction to start the prime.
Turbo Habanero
4,229
Tucson,AZ
Shitty... So what do you think ? Cause I'm at a lose right now.
To scared to attempt starting it with the efi fuse without the system being primed.
