Front Main Seal Replacement
ShadowMKIII
20
Huntingdon, TN
Anyone have a step by step on replacing the front main oil seal. I got both the 3527b and 90311-52003 seals... I dont want to have to pull off alot of stuff I dont have to... I have searched for a how-to but am unable to locate it.
Thanks in advance for the help as I am about to crawl under it...
Mk3runner
2,033
Nor Cal
Gotta pull crank pulley and timing gear and belt.. Not a step by step but that's the jist of it
Plus have a big torque wrench.. Crank pulley specs is somewhere around 200 iirc
ShadowMKIII
20
Huntingdon, TN
Can I get the crank pulley off without taking off the fan? also am I gonna have to worry about retiming the car?
ShadowMKIII
20
Huntingdon, TN
well there is not going to be any work today... The air compressor threw the breaker to the shop as they were doing some body work on it as I was under it.... O well looks like next weekend it is... Atleast then I will have a lift... and can do alot more research...
Mk3runner
2,033
Nor Cal
Your gonna have to check the timing when your done.. Just tdc it before hand. I'd pull the fan myself.. Timing it isn't hard.. Just make sure belt tention is good
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
This is a fairly simple procedure.
Disconnect the battery first.
Drain the coolant, pull the radiator hoses. Remove the fans, waterpump, shroud, and radiator. Remove all belts. Pull off the top timing belt cover, align the engine to TDC using the marks on the cam gears to the notches on the rear timing cover.
Pull the lower belt tensioner. Remove the bolt from the front main pulley and then the front main pulley itself. Chances are you'll need a puller to get the pulley off. Remove the lower timing belt cover. Inspect the timing belt before you pull it for problems - cracking, or any sign that it's slipping forward or back.
Inspect the timing belt tensioner at the same time.
I'd recommend replacing the cam seals, front main, and oil pump shaft seal all at the same time. The oil pump shaft seal is a bit more work, but it's pretty obvious what needs to be done from this point.
Bolt it all back together in reverse order, jumper your diag block and check the timing just to make sure.
Might want to consider replacing the timing belt if it's getting long in the tooth. Might as well while you are there. You will have to check/reset timing anyway.
ShadowMKIII
20
Huntingdon, TN
Thanks man.... I will have all the other parts in by this weekend so hopefully I can get it all replaced... Then move on to the next issue... Phew im gonna be broke before its all over... lol...
ShadowMKIII
20
Huntingdon, TN
lol... it seems like when I want to do a simple procedure I end up spending an entire weeks check... lol... But thanks for all the input guys. It is helping out alot
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
Not really. ;)
It's pretty "cheap" compared to having to tow your car home from a trip and having your wife say, "I knew it was gonna break down," and "I told you so."
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
Zumtizzle;1307319 said:
Not really. ;)
Well I do not have a wife but I do have a girl friend, and basically if I say I need a oil chnage she will say what broke, I just smile and walk away.
ShadowMKIII
20
Huntingdon, TN
Not really. ;)
Well ya'll talked me into it... Now im off to find the best place to get the timing belt and tensioner from... search button here I come!
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
I would just do the basic timing belt and seal. I would really consider getting an oil pump drive shaft seal (not sure if that's the other one you got) because its right there and easy to get to right now. Water pump isnt really needed if you don't feel any play in it and no leaks, and tensioner isn't really needed if it spins smoothly without sounding like there is sand in it. Consider camshaft seals while you're there if they are leaking at all. If your timing belt looks good and new there is no reason to really do that either if you are on a very tight budget.
Keep something in mind, your time has value ;)
Replacing the other seals and a timing belt is easy while you have everything off to replace the main seal. And, it's not that expensive...we're talking about 3 more additional seals and a timing belt. It's the mileage on the belt that matters, not how it looks. BTW - SupraRich sells Gates timing belts...an upgrade over OEM IMO. For the tensioner, I would at least replace the spring if everything else is good...do not over torque the tensioner and check belt play after 500 miles for a possible re-adjust on the tensioner.
The water pump is up to you...it's removal is not required to get to the main seal. I would give it a through inspection though. If you see any coolant at the weep hole on the bottom, it's on it's way to failure.
grimreaper
2,180
Dallas
cough cough, replace the crank timing belt pulley. Newer one has more welds holding on the belt guide. Make sure the keyway is good too. I always replace the bolts i take off that are vital (crank bolt) and make sure the crank snout has a nice layer of antisieze on it for future work.
92nsx
2,957
Clearwater, MN
Sig worthy :rant:
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
I can already smell an argument coming... "They're not welds they are staked".:runaway:
