For those of you with a 4" turbo inlet: what filter do you use?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
emericaskater285;1943261 said:
Do you have it clamped on? When I put it on it would stay, but when I tightened my clamp it wanted to pop off. Also couldn't force it past the bead, so I didn't end up using it. I tried and tried to get that to work, but it just wouldn't lol.
What's the length on that? If it'll fit in my engine bay, I'd likely take it off your hands. :)
The K&N is not a good filter. It gives you great airflow, sure, however, it doesn't actually filter anything smaller than pea gravel. It'll work fine in ocean climates, or any place with high humidity, but where it matters, use one of the filters that works - AEM and Blitz are the best, IIRC.
Now that i think about it i think i had the same thing happen so i just cut the bead off and it stays on fine.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
76
Atlanta
GrimJack;1943394 said:
Correction: Apexi / AEM are the best available, but the Apexi doesn't come in a large enough size that I've found.
This is what i've come to learn. Really wanted the Apexi, for its internal design.
1988ma70supra
553
San Antonio, Texas, United States
I don't think the K&N is a bad filter but the AEM dryflow has out performed the K&N in almost every test aside from airflow as GrimJack stated.
View attachment aem test.pdf
The tests were done with filter size 4" inlet & 9" tall accross the board
It was more convenient for me to get the K&N at the time since it was available locally and I was test fitting in the parkiing lot. Although if i had done my homework and checked for fitment ahead of time; I would have definately gone with the AEM dryflow. I personally decided to add a prefilter to help with filtration and liquid contamination.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
76
Atlanta
Old-ish thread, but for the record, i ended up getting the AEM dry-flow filter.
That is what mine looks like. The aem dry flow filters are awesome. Been using mine for about a year and a half and it still looks new.
TaylorRacing
53
San Diego
I'm not sure you guys have the room but i am using a Napa 6637 dry filter. its large but is thick and reasonably priced.
cross referenced the part numbers too in case you have connections through other avenues
ACDELCO A1474C
AIR REFINER ARM08-5011
BALDWIN FILTERS PA2818
BIG A 94637
CATERPILLAR 3I0003
CARQUEST 88637
CUMMINS 2912986
CUMMINS 3912020
DONALDSON B085011 H
DONALDSON ECBO85011 H
DONALDSON ECB085011 H
FLEETGUARD AH1141
FLEETRITE AHR81141
FRAM CA6818
GFF AF359214
GENERAL MOTORS CORP. 25177209
HASTINGS PREMIUM FILTERS AF2329
HERCULES B085008
KRALINATOR LA1458
LUBER-FINER LAF2533
here is a picture of mine, this was mach up before making my mounting brackets but you get the idea on the size
