Fog Lights Switch
JDMMA70
2,550
Houston
I want to check to make sure, but do the foglights only turn on when the headlights are up and the car is running. Or can I have the car off and turn on the headlights and the foglights.
Because I didn't start the car but I turned on the headlights but the foglights wouldn't come on. And since the engine is undergoing a headgasket fix I can't start it
So help would be appreciated.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Yeah fog lights only turn on when the car is on with the head lights up. Can be rewired so they can come on with out the head lights though
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
car doesnot need to be running. just flip on headlights til they flip up and come on then hit Fog switch.
JDMMA70
2,550
Houston
I fliped the headlights up and press the foglight switch and they aren't turning on. My fuse isn't blown and the foglights worked when I purchased the car.
The Reaper
Jan 10, 2006
1,909
Florida
hmmmm check the wiring going to the back of the housings. how long ago did you purchase the car??
JDMMA70
2,550
Houston
Car was purchased a week and a half ago.
Foglights were working. Now they don't. I was thinking maybe one of the bulbs went out?
The Reaper
Jan 10, 2006
1,909
Florida
not in either of my cars that i've had. the one i have now is not wired up stock. its tapped into the front corner lights so they come on with the parking lights now.
but im positive the car does not need to be on.
plaaya69
87T Supra
Nov 18, 2006
947
10
Lake County, IL
The fog lights will work with the car off and the key out of the ignition. It does that in both of my 87's. Also I think that their is a CB(Circuit breaker) for the fogs but I could be wrong.
if you rewired by the SOGI write ups, then you tapped into the gauge fuse...guess what, key has to be on for them to come on (like mine, but I like it so I don't forget to turn em off like some cheap aftermarket ones)
JDMMA70
2,550
Houston
My car is an '88. So could a bad bulb stop both from working or is it the wiring. My fuses are good. Haven't checked the relay switch yet. Mind you my foglights worked when I purchased the car.
The Reaper
Jan 10, 2006
1,909
Florida
if you have a friend with a supe try his switch. if that doesn't work check the wiring and the bulbs. takes 10 mins to remove them including taking the under covers off.
im glad i was right about something and some one confirmed it HAHA
JDMMA70
2,550
Houston
i have no friends near me that i know of with a supra
osama1234
Noob
Jun 30, 2007
87
vancity
Ok i'm doing the SOGI fog mod.
I've got an 86.5, and the difference i'm finding in the SOGI 87,88 and 89+ mod is that for some reason in the 87,88 in step 2 (of the link i provided). He says to find 'wire 2' white/green, and basically ground the relay. It makes absolutely no sense, so i haven't done it. It might be that i'm using
http://www.cygnusx1.net/supra/Library/TEWD/MK3/manual.aspx?S=Main&P=076, and maybe 86.5 is wired differently from the 89's TEWD which i read.
Please let me know if that step makes any sense, to me its simply having a relay that is always on. (defeating the purpose of modding the fog switch, which he does also).
Thanks
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
This maybe far fetch...but, your high beams aren't on are they? The fogs will turn off when the high beams are on. Just thought I would ask. I've seen threads titled "Help, my car won't start"....and low and behold, they were out of gas. Usually checking the obvious first is the key. Sorry if this offends you, but had to ask. Good Luck either way.
osama1234
Noob
Jun 30, 2007
87
vancity
Update: In case someone is searching for help and finds this thread.
I just wired it up in a way that made sense, and long behond it worked. Btw, when i say in a way that made sense, it isn't like the way SOGI's link i posted earlier for 87,88. I later found out after the 87 didn't work, and also wiring it up myself, that there's a SOGI 86.5 method posted. AFAIK, it seems they take a rather long route.
If your car is 86.5 and similarly wired up (not random coloured wires), there's one pin for the relay that has two wires coming into it, i think they're blue and white wires, i basically cut those two wires away and connected the two cut wires together. As for the two wires going to the same pin of the relay, i connected that to 12v.
Finally, take i think the 4th wire (3rd from the top) of the fog light switch, i think it was red/black, and taped the side going into dashboard, and with the switch side just grounded it to chassis.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
lol - that's pretty damn funny, but right on the money!
If you've rewired your foglights, they don't care about the highbeam setting any more, though.
