finnaly started...project wanna go fast
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
im in whitehall/baldwin area....i'm less than 10 munites away from pittsburgh...i've been in gressnsburgh before youre not far away...
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
i sure hope so...
so plan for NOW is to get the motor built strong, and get a 57 trim upgrade...once i get done with the rest of the car and get the most out of the 57 trim, i can rebuild my turbo system again and go ffim...just figured id start somewhere
suprahooked
Built 7M
Jun 20, 2006
1,160
pa
Lol i did a lot of work down that way.
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
i've been puking and shitting my insides out for the last 3 days, but i did manage to get my ass out to lowes and get some bolts to mount the engine on the stand. i'm hoping to rip everything out of the engine bay new years...then clean fix rust unde battery tray and paint the bay.
GetAttachment.aspx
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
decided to start of easy and pulled the head off the motor yesterday...i dont feel like ripping everything off the engine bay yet and i've been spending time with the lady friend cause shes leaving this week to go back to school...
coolant was pretty much drained from the block, yet coolant on my pistons?
all of the exhaust ports except cyl#1 looked lie this...oil puking out the valve seals
so i guess i found out why it smoked so bad at start up :aigo:
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
didnt see that quick enough^^^^
pistons are sold i think...
going for the oem rebuild with MHG and arp's...57 trim ct26...i decided to pick up more classes at school so money is better spent at school.
doing some research though and it looks like i will still be able to reach my goal of 400 whp or damn close to it...
parts ordered:
aisin oil pump
gmb water pump/goodyear t-belt and tensioner
OEM gasket kit.
i also just received a 3" turbo elbow from a member here...took it to school and sandblasted it then painted it high temp black :icon_bigg looks purdy i'll post a pic later.
o and engine goes to machine shop when gasket kit arrives...working on getting everything else i need.
2 q's i got:
i should wit till the machine shop is done to order my mhg right?makes sense...what RA shoul i tell them to machine head/black at?
and where can i find OEM rings (other than stealership).i dont wanna run chrome rings...
kotu100
1,899
Easton, Ma
i believe the MHG needs an RA of 15 or better to seal correctly. also yea you should wait because you have to figure out what size MHG to get depending on how much material was removed by the machinist.
you could always get some rings off ebay... i got everything on there.
which pistons are you gonna be using?
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
i'm goin to be using the pistons that came with the motor.they have perfect pistons to wall clearance and are scratch free.the motor was rebuild recently, i didnt believe the guy when he told me but it was indeed rebuilt.also all the rings on ebay are chrome rings which from what i've read are bad for our block...
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
kotu100;921160 said:
hmm weird, the rings i got weren't chrome.
i believe these are the same.
http://cgi.ebay.com/ebaymotors/82-9...016QQitemZ260209403985QQrdZ1QQsspagenameZWDVW
i could of sworn i read an ebay add that said npr's where chrome...they dont have them .040" over anyways but i think they do make them...i'll have to investagate more thanks...
EDIT: http://cgi.ebay.com/ebaymotors/87-9...198597342QQcmdZViewItem?hash=item200198597342
says they are chrome
Clueless;921161 said:
You gonna be doing the engine work yourself?
yes this is gona be my 4th rebuild but this one is the most exciting lol...
btw heres my pretty elbow...looks better than when i got it...sandblasted and painted.
ALSO:
BIC pre 89 solid motor mounts, engine torque dampner and 3" test pipe ordered!!!cant wait...
Clueless
980
Columbus, Indiana
don't you have to worry about the tight tolerances? All due respect to Jon, he says I should leave it to the pros... :dunno:
