Finally Finished!!! Woot!!! Thanks!!
jgcable
180
Milford, CT
I finally finished the head gasket on my 1987 NA Supra. Its just a daily driver.
I replaced:
Head gasket (stock Felpro)
I stripped the head and had a machine shop repair a rear water jacket and plain it flat.
I installed new:
valve stem seals
injector cushions
injector o-rings
water pump
timing belt
all new gaskets
front cam seals
New Toyota head bolts (I torked them to 72ft lbs. in 5 passes)
I painted an detailed everything
I spend about 4 weeks on it. I studied until my eyes bled, I asked tons of questions here and I followed the TRSM and the Haynes manual that I have.
I didn't have a single bolt left.
I pulled out my timing light and started her up this morning. She started right up but was running like crap. I broke out the timing light, jumped the diagnostic port as per the manual directs and set the timing to 10 degrees BTDC. She is running beautiful. I let her run for around 20 minutes and removed the radiator cap and had to put in about 2 pints.
I started her back up and she started instantly, idles at 650, no leaks, no vacuum leaks. Basically she purrs like a kitten.
I am so happy. Thank all you guys so much for all the help. I couldn't have done it without your help!!!
jdub
Feb 10, 2006
10,730
Valley of the Sun
Don't forget to re-torque those stock head bolts after 5 complete warm-up/cool down cycles. Change the oil and filter now...do it again after 500 miles.
Feels good to have that done huh ;)
jgcable
180
Milford, CT
It does feel good but I certainly am not looking forward to ripping the entire motor apart again to re-torque the heads. What a pain in the butt after spending a month working the car every spare moment I had.
Is a re-torque really necessary on a n/a totally stock car that is not beat on??
I used a Felpro gasket, I copper sprayed both sides and I used new head bolts and torque'd them to 72ftpds.
Basically I am pretty "done" with working on this car for the time being.
A couple of buddies of mine who are mechanics said they would re-torque if the motor was built of it it was a turbo but for a stock automatic car they wouldn't bother with a retorque.
mattsplat72
is sofa king
Jan 17, 2006
1,737
In a nut shell YES think of all the time you just spent .... why waste it on a simple step ? 4 weeks hard work lost because you got lazy at the end . What was the point of doing it right if you just ge tlazy at the end
ReTorque the damn bolts silly
jdub
Feb 10, 2006
10,730
Valley of the Sun
Well, you're not "ripping the entire motor apart" to do a re-torque...at least I hope you don't ;)
The question you have to ask yourself is: Do you want to risk doing the entire HG job again in 6 months?
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
You just need to pull the cam covers. Make sure you read the proper proceedure for re-torquing. It shouldnt take you more than an hour max, and then you can hang up your supra mechanincs hat for a while.
jgcable
180
Milford, CT
I am going to do the retorque. I'll give it a week of driving around and retorque. That should be 5-8 heat cycles and around 100 miles tops. Should I wait longer?
How many miles should I go and what is the retorque procedure? Do I loosen and retighten or just check tightness?
Thanks guys...
jdub
Feb 10, 2006
10,730
Valley of the Sun
Good decision ;)
That's plenty of time/heat cycles. You want to follow the TSRM pattern, use a breaker bar (not a torque wrench) and just "crack" the head bolt counter clockwise...that is the 1st movement you detect (1/4 turn max). Then re-torque to 72 ft/lbs...you can go to 75 ft/lbs if you wish.
jgcable
180
Milford, CT
Here is a simple question...how is it possible to pull the cam covers and retorque in under an hour??
It looks to me that in order to pull the drivers side cam cover I have to remove the intake manifold. This means I have to remove all the dreaded vacuum hoses and sensors that are under the manifold that took me 3-4 hours to get all back together. If I pull the throttle body and the throttle linkage it looks like I will only be able to get the passenger side cam cover off. The intake manifold assembly is in 3 parts...
Throttle body
that short piece inbetween the throttle body and the intake runners
The curved intake runners
the short piece between the curved runners that connect them to the head
What I am asking is... can I slip the cam cover off by just removing the throttle body just like I have to do when I changed the spark plugs??
jgcable
180
Milford, CT
Jaguar_5;1111667 said:
All you have to remove is the air piping to the TB, and the TB itself
Yea I understand that but it looks like the drivers side cam cover is directly under the intake with an inch to spare. Are you saying there is enough clearance to slide it sideways and out??
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
yes. absolutely no need to remove the upper plenum
AJ'S 88NA
2,419
Florida
It's easy to do just leave the coolant lines hooked up, disconnect the linkage, and what ever else would keep it from being flipped over on the upper intake manifold.
cuel
1,536
Baytown, Texas
Yup. As they said, it's pretty easy. Should take you a half hour, maybe a bit more.
Make sure you have another throttle body gasket on hand, just in case you damage the one that's on it now.
