Drivers Door WONT CLOSE!!!
Yblegal91t
it finally runs!
Apr 22, 2006
331
C1 outer
ok, i had the drivers door open for a while when i was working on it in the garage and now it wont close. it's definitely the latch is not hooking and when i put the key in and lock/unlock it it triggers something electronically and locks right back up after unlocking it. WTF
this has never happened before. please help
Yblegal91t
it finally runs!
Apr 22, 2006
331
C1 outer
tried wd-40 i soaked it and also teh 1jz swap. :icon_bigg
still nothing...
im out there now taking the whole assembly apart. i did notice there is a small crack in the thin metal behind the handle and the handle does not line up right. i should get it.
if not ill have to go 2jz.:sarcasm:
*sigh* still didn't answer my question
Try lifting up on the door as well, if the hinges are fucked it won't line up (found this out the idiot way from asshole shop bringing a lift down on my door)
Yblegal91t
it finally runs!
Apr 22, 2006
331
C1 outer
yes i know it wont let you lock it with the key in.
i took apart mostly everything and backed out the only screw on the inside plate that holds the latch and was able to turn the lock back the normal way. How it got like this i have no idea.
And i was working on the throttle cable linkage to the gas pedal
i will take some shots of the car tomorrow. this weather is crazy nice!
