Heres a breif description and a couple of pictures of my ride which has slowely progressed and turned into something special and worthy of posting up!
Toyota Soarer - MZ20 1989
Engine and mods
7MGTE
3mm HKS MHG
Titan cam gears
Custom inlet manifold
Q45 throttle body
Driftmotion thermal inlet manifold gasket
K&N 4inch pod filter positioned behind front bumper with 4" turbo inlet pipe
550cc injectors
Aeromotive fuel pressre regulator (with Redline fuel pressure gauge)
600x300x75mm intercooler
custom aluminium intercooler pipes 2.5/2.75" turbo side (depending on turbo), 3" plenum side
Walbro 255 intank pump
Eboost 2 electronic boost controller
Garret gt3040r 0.82 rear and 0.7 front/ trust t78 33d 17cm2
stainless steel tubular exhaust manifold with custom t4-t3 flange converter
Trust type r 50 mm external wastegate with 0.8-1.2 bar spring
Hks ssqv bov
Ems 8860 ecu
LS1 coils with built in ignitors
MSD 8.5 Ignition Leads
Braided lines and fittings throughout
HKS oil filler cap
koyo racing 53mm aluminium radiator
Spal 12" thermos fans (x2) - push type
Exhaust (3 different setups)
3" turbo back exhaust with single 3.5 inch hks mid muffler and 4" tip (gt30r setup)
3" turbo back, high flow cat, centre muffler and blitz nur spec cannon (t78 setup)
3" side pipe (track setup)
Transmission and driveline
Tremec TKO-500 gearbox (26 spline ford input shaft, billet broze shifter fork pads)
Pro 5.0 short shifter
OS Giken twin plate clutch with custom solid centre puck discs (suit ford spline)
4.3:1 TRD mechanical 2 way LSD
Stainless Braided clutch line
Suspensions, wheels and brakes
Work meister Sp1 (18 x 8.5 +33 and 18 x 9.5 +40)
Rays duraluminium wheel nuts (blue)
custom polyurethane eccentric upper control arm bushes (Front)
cusco zero 2 coilovers - soon to be replaced by Aragosta S-Type
Cusco front strut brace
Braided stainless brake lines
Cusco brake master cylinder stopper
Ferrari F40 brembo kit (front): 332x32mm rotors 4 pot calipers with pagid rs4-2-1 black pads
Interior
Pivot electronic - oil temp, water temp and oil pressure guages (60mm)
Pivot tacho with sequential shift light (90mm)
Autometer boost gauge
Pivot type x speed meter
Momo corse steering wheel
Alpine MP3 Deck
Alpine type R rear speakers
MB Quart 4" components front
Alpine Type S 12" subs (x2)
ALpine MRV-F307 Amps (x2)
Response 800 watt RMS mono amp
Innovate LM1 datalogger with Aux Box
Exterior
ma70 lip spoiler
aftermarket smoked front indicator lenses (rare as)
6000k HID (china kit)
Future Upgrades
rebuild motor with forged internal
aftermarket sway bars (want tanabe/arc)
rear brake upgrade in the making - consisting of 34gtr brembo 2 pot calipers, trying to fins some suitable 22mm thick rotors between 322 and 324mm
Best 1/4 mile time to date = 11.89 @ 118.27 MPH (Quit Motorplex on 255 MT ET street)
Highest HP pull to date = 442.7 rwhp at 19 psi (Motorvation 07 dyno comp)
few pics of my car in stock form....
and a couple more recent pics
Heres a couple of vids.....
http://youtube.com/watch?v=4r83IkbmFOM
http://s16.photobucket.com/albums/b43/stagezilla27/?action=view¤t=Untitled_0004.flv
http://www.youtube.com/watch?v=pHVcCJg6K-0
http://s16.photobucket.com/albums/b43/stagezilla27/?action=view¤t=Untitled_0005-1.flv
Engine and mods
7MGTE
3mm HKS MHG
Titan cam gears
Q45 throttle body
550cc injectors
Hks ssqv bov
Ems 8860 ecu
HKS oil filler cap
Interior
Alpine MP3 Deck
Exterior
ma70 lip spoiler
Future Upgrades
![](http://img125.imageshack.us/img125/9163/soarer13hp6.jpg)
![](http://img510.imageshack.us/img510/613/soarer16qs5.jpg)
![](http://img81.imageshack.us/img81/1352/p1020230lg0.jpg)
![](http://img177.imageshack.us/img177/4885/img0031pc2.jpg)
![](http://img125.imageshack.us/img125/8291/p1020076mg9.jpg)
![](http://img84.imageshack.us/img84/3509/z1qb1.jpg)
![](http://img300.imageshack.us/img300/3033/z2pj4.jpg)
![](http://img218.imageshack.us/img218/9412/z3er3.jpg)
![](http://img125.imageshack.us/img125/6950/untitledb2222bi4.jpg)
![dsc0051swh3.jpg](http://img165.imageshack.us/img165/5066/dsc0051swh3.jpg)
![p1020701sok4.jpg](http://img63.imageshack.us/img63/621/p1020701sok4.jpg)
![p1020757ez7.jpg](http://img144.imageshack.us/img144/8315/p1020757ez7.jpg)
![p4090100ca5.jpg](http://img510.imageshack.us/img510/4412/p4090100ca5.jpg)
