differential gear ratio
willfish
been here since 2003
Apr 23, 2005
648
Pittsburgh, Pa.
how many different gear ratio's are there ?
the 3.91 , 4.3 ??
what years came with what gear sizes ?
an what differences would it make if you put a different differential in your car other than the differential that it came with ? etc ....
would someone school me a bit on the subject ?
Will
Ma70.Ent
1,871
NJ
the 3.91 , 4.3 ??
Will
3.73, 3.91, 4.10 (I think), and 4.30 as far as I know. I heard you can use some differential ratios from Toyota trucks too, lol.
willfish
Apr 23, 2005
648
Pittsburgh, Pa.
i cant remember what came with my 90 T manual ?
but can I use a different gear ratio differential from another turbo manual ? if so, anything specific i have to do or dont ?
Will
Scruggs86.5T
298
Slidell, LA
My 86.5 n/a came with a 4.55 lsd. There is a plate in the engine bay with codes for the rear end. Mine was G255, I am switching to the 3.9 lsd though.
Saavedro88 said:
The number you're looking for is the one in the "A" category.[/QUOTE
Scruggs86.5T
298
Slidell, LA
sorry forgot this part
bryanintexas said:
(pulled from celica-gts.com)
Toyota Differential Codes
The following is a table of Toyota differential codes. These codes are applicable to all Toyota models and years. You will find this code on the VIN plate in your car, typically on the firewall.
The code is comprised of four digits. The first digit is a letter that represents the ring gear diameter. The second and third digits are numbers that represent the differential ratio (Number of driveshaft rotations for each axel rotation). Lastly the fourth digit is also a number that represents the number of pinion gears and whether or not the unit is equipped with limited slip.
Examples
T382 = 6.7" Ring Gear @ 3.417:1 ratio, 2 pinions w/o LSD
F293 = 7.5" Ring Gear @ 4.10:1 ratio, 2 pinions w/ LSD
F303 = 7.5" Ring Gear @ 3.727:1 ratio, 2 pinions w/ LSD
Differential Codes
First Digit Second/Third Digit Fourth Digit
Ring Size R&P Ratio Pinions/LSD
A = 138mm
B = 145mm
C = 6.25"
D = 6.62"
E = 7.1"
F = 7.5"
G = 8"
H = 9"
J = 9.25"
K = 9.5"
L = 10.5"
M = 12.5"
N = 13.5"
P = 14"
R = 162mm
S = 6.38"
T = 6.7"
U = 6"
V = 10.6"
W = 15.5"
X = 142mm
Y = 158mm
01 = 3.30
02 = 3.36
03 = 3.545
04 = 3.556
05 = 3.70
06 = 3.889
07 = 3.90
08 = 4.111
09 = 4.222
10 = 4.375
11 = 4.444
12 = 4.625
13 = 4.79
14 = 4.875
15 = 5.125
16 = 5.286
17 = 5.60
18 = 5.714
19 = 5.833
20 = 6.167
21 = 6.667
22 = 6.78
23 = 6.833
24 = 7.64
25 = 4.556
26 = 5.571
27 = 3.364
28 = 4.30
29 = 4.10
30 = 3.727
31 = 3.909
32 = 6.591 or 5.583
33 = 7.503 or 5.583
34 = 6.781 or 4.786
35 = 7.636 or 5.60
36 = 4.778
37 = 3.583
38 = 3.417
2 = 2/no LSD
3 = 2/LSD
4 = 4/no LSD
5 = 4/LSD
blackturbona
255
kirkland
hmm just went to go check my diff...and my plate on the firewall is conveniantly not there... anywhere else i can see it? besides on the diff (even then.. where on the diff? lol)
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
Theres another in the door jam iirc.
It's not hard to see the LSD sticker if you have one. Look under the back of the car, big red sticker on the pumpkin with white writing. It might be dirty/hard to see, the first time I looked I didn't see it.
IJ. said:
Didn't the 1G cars come with lower than 4.30?
Always forget about that one
Scruggs86.5T
298
Slidell, LA
bryanintexas said:
Your axle code reads "G285"
G = 8"
28 = 4.30
5 = lsd
Yeah, sorry I know how to read, it says G255. It comes out to be a 8" lsd with a 4.556:1 ratio.
The picture of the tag was a quote, just for a reference.
