Dang my head has a crack guess I should throw it away ..........naaaaaaaaaaa
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
Well I have been on here for a long time :: tumbleweed ::and I have never scene this done yet here on any of the supra based forums
since I have put some money/time into this head it was worth fixing and not given up on it
Well this is the crack started it all....I found out after I popped the exhaust seat out the crack went all that way into the port this was a big :kickinthenuts: I must say
So after a fair of grinding all the way into the port :yikes: it was welded up then ball peed after each pass of filler rod to bring the slag up form the drity cast and you get this
looks like a mess eh :cry: but she is not done yet so I sent the head off to get the new seat and valve cut in
looks good so far but need alot of grinding smoothing and carving
fast forward 2 hours or so :burnout:you get this
Well now it look like it was never cracked :: rave ::
sure I could have replaced the head but were is the fun in that
time for some :beer::drink1::: alky :: and then maybe some ::hooters:: at the bar
then once I send it back to get the final plain done I am going to cc the head
Turbo Habanero
4,229
Tucson,AZ
wish i could do some work like that. i would have just put my head down in shame and shook it as i walked out the garage cursing
Really impressive work. Great job
te72
Classifieds Moderator
6,621
9
WHYoming
Looks good man, just a bit of touching up/machining and nobody will ever know. :)
Is it just me or are all of you blind? :nono:
Prediction: It'll crack either side of the weld the 1st heat cycle....
I only say this as to repair that properly would mean preheating the head to 500c before welding and milling to the full depth of the crack this in turn would make the head T0 (soft) so it would need to be reheat treated and to do this ALL the steel parts need to be removed/replaced.
mk3_7m
536
melbourne
Best wishes to you, Hope to God that wield was enough >.<.
Finding a 7m for me is getting harder as time flys. I wonder what it would take TMC to reman one for me XD.
te72
6,621
9
WHYoming
Ian, I said it *looks* good, but I'm still excited to see how well the repair holds up. I've been impressed before. ;)
That said, I definitely wouldn't be doing this myself, this is some pretty brave territory... Good luck Nash!
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well the sprint car's motor crack has not returned and that gets shit kicked all season long
this was done properly and with the right rod and very common at a head shop
I have no worries Ian I have scene fixed cylinder heads pumping 1000 blown horsepower and they hold up
for how long who knows but for the life of this cylinder head it will be good to go
just an idea these guys are crazy only do there own heads thou
http://www.weldingtipsandtricks.com/welding-aluminum-cylinder-heads.html
oh I all so found out how toyota's heat teating take's place it's rather fast and simple and this was done wiht my head as well when it was fixed
http://ip.com/patent/US4695329
NashMan
Aug 5, 2005
4,940
17
Victoria BC
^but it is done all the time and hopefully done properly
i hate to say this but this is not a new thing that just came out of thin air
te72
6,621
9
WHYoming
GrimJack;1715617 said:
Given that Ryan's average annual mileage on the Supra doesn't usually make double digits, this should hang on for years. ;)
Seems that every other badass 7m I know of is like this. Rebuild, enjoy, destroy, and repeat as needed. It's like laundry, really... :)
