CPS correctly timed?
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Im doing a 2jz swap into my mk3 as some of you know. I drilled out the slot for the timing to be set. I searched and only really found one good picture:
Im not sure if I fully understand the caption. I figured the bar sticking out should be right infront of the sensor part. I think i got it set correctly just want to make sure.
Correct? (at TDC)
fonz87
89 Turbo!!!!
Nov 17, 2007
642
Streamwood, IL
omfg, when i did my timing, i thought you were suppose to align it with the sensor part! Shit! My car has been running little different.
Thanks Fletch and poodles for this, i gotta fix my shit now.
8,871
Poodles;1149312 said:
Timing is adjusted with a timing light...
Hell, I never took the cap off mine when I installed it...
No need to take the cap off at all. All they needed to do was align the matchmarks.
shaeff
Kurt is FTMFW x2!!!!
9
Around
Man, I need to make another (new) diagram. That one isn't the best. I should really get on that.
For what it's worth, I always pull the CPS cover to check the integrity of the gasket, and make sure there's no oil leaking inside. :)
Mine was brand new, so it wasn't necessary :biglaugh:
