CPS Causing miss
supradjza80
Mr. Formula SAE
Apr 24, 2007
782
Appleton, WI
www.uwracing.com
Guys,
My car has a miss at idle and I have gone through and checked everything in the ignition system and believe the only culprit could be my CPS.
I have tried new spark plugs BCPR7ES at .028 just in case my Denso iridiums (IQ20's) were the cause, no change
All of the below items were ohm'd within spec
Plug wires (NGK's changed last fall) all were perfect
Ignition Coils
ISCV
TPS
02 sensor
The only thing that was out of range was the CPS, which ohms about 220-240 ohms on each of the three measurements. Now, I believe based on the above information that this is likely the cause of the miss. But the car starts every time, runs great in boost and has no issues like I would think a bad CPS would cause(random no starts/stalls). Since it is a 500$ part brand new (I want a new one), I would like to be certain it is the cause.
Has anyone else seen the CPS cause this sort of issue, but not have the car have starting/staying running issues?
Thanks,
Dave
supradjza80
Mr. Formula SAE
Apr 24, 2007
782
Appleton, WI
www.uwracing.com
IJ.;1388064 said:
Can't see why Dave it's adjustable, I bought a brand new CPS and it was so far out it wouldn't fire the MoTeC till I adjusted it.
Ahh ok, well I just read this part of the service manual and figured it was not adjustable
"If the gap is not within specification, replace the cam position sensor."
I will check it later this week or maybe this weekend and see what I find out.
That said does anybody know if being out of the range for resistance can cause a problem? I don't believe the air gap and resistance are related but maybe (electrons really are not my forte).
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
The CPS generates a digital pulse/frequency every time the signal rotor passes through the magnetic field of the pick-up coils. G1 and G2. This digital pulse/frequency allows the ECU to calculate/detect the engine speed and position.
If the referred air gap is greater than spec, the pulse will be weak in amplitude, short in pulsewidth, or both. This would result in a miss.
If the resistance is too high across the pickup coil, it has roughly the same affect as too great of an air gap.
If you have both...severe idle problems and starting issues.
supradjza80
Mr. Formula SAE
Apr 24, 2007
782
Appleton, WI
www.uwracing.com
Alright, I checked the gaps on the pickups, one of them was just out of range. I but them both right down to .008" and did the NE pickup as well since I was in there. Put it all back together and it is still the same, I still have the miss.
Any thoughts?
I will add some pictures of the inside of the sensor, it still looks brand new...
supradjza80
Mr. Formula SAE
Apr 24, 2007
782
Appleton, WI
www.uwracing.com
Alright pictures.
First - Is it normal for the factory wiring to the CPS to have splice in it? I took the old crappy electrical tape wrap off of the wiring and re-wrapped it with scotch Super 88
unwrapped
wrapped
Now to the interior of the CPS (it has a recently replaced gasket and factory plastic cover)
Camera sucks even on micro... but its the only pic of the "gap"
overall pic
I was hoping this might fix it but once i measured the gaps with my feeler gauges I was doubtful it would do anything. Just waiting for it to warm up to time it it was starting to miss...damn car :)
thevork
ShoarmaTeam Member
I just saw this thread and I got really curious about how much your car misses @ idle.
Is it constantly or every 5 to 10 seconds ?
This because my car does this too after upgrading to 550cc+lexus afm, and two other supras with a similar setup do also miss every 5 to 10 seconds @ idle so we figured it to be "normal" behaviour caused by the lexriemer mod.
The only thing I saw on these boards that probably fixed this was the COP mod.
Don't know if this helps, but just making sure you're not chasing ghosts. :)
supradjza80
Mr. Formula SAE
Apr 24, 2007
782
Appleton, WI
www.uwracing.com
yeah, i may be chasing a ghost in this case. Ill take a video of it at idle put it kinda sounds like popcorn every 5-10 seconds (doesn't do it during warm up but does do it constantly while warm). I am still stock afm/stock injectors/stock pump. just some other bolt ons. Thing is my car went from not doing the pop (all last year) and this year just started to miss at idle and even continues to do it if you hold it at a constant slightly raised rpm with no load. If its normal that's fine but I just don't think that is the case. AFR's at idle are in the 14.3-15 range so it appears it is nothing to do with warm up enrichment not turning off (haven't checked the temp sensor)...anyway I gotta go to bed, the morning is going to come early!
CajunKenny
Nov 15, 2007
3,255
Washington
I have to say that tracking down a slight miss or hiccup in idle can be maddening! Have you checked for codes?
That said, I'll throw out some of the things that I've seen and hopefully some other folks will too.
An oil leak in the spark plug galley can cause issues when there is enough oil (typically around #6) around a plug/plug boot to cause the plug to ground out to the head.
Bad Plugs and Plug Wires.
Incorrect Plug Gap.
Vac Leaks.
And one last thing that I experienced with a miss/hiccup in idle is that after replacing the injector o'rings and insulators things improved two fold. Basically, all of the rubber parts related to my injectors were dried and cracked.
The inside of your CPS looks CLEAN by the way!!! :)
dumbo
1,913
Albera, Too Far North
Have you done the external ground on the igniter? I recomend it, it only takes 15 minutes and two or three dollars.
On a side note, mine randomly does miss when warm eary 5-10 seconds, but only occasionaly. Maft pro speed density. So who knows..
Oct 11, 2005
3,821
26
Thousand Oaks, CA
Looks like the pickups were replaced and the CPS rebuilt, or its nearly brand new.
Did you get measurements for the gaps? Also, is the top reluctor flush with the top of the G1/G2 pickups?
supradjza80
Mr. Formula SAE
Apr 24, 2007
782
Appleton, WI
www.uwracing.com
I believe it is still the original CPS from the car. That said, the gaps for g1/g2 were pretty good as they were. One of them was just out of range (don't remember which). that said I adjusted all 3 of the gaps down to .008" and yes the reluctor is flush with the tops of the pickups.
Oct 11, 2005
3,821
26
Thousand Oaks, CA
Then I'd say the CPS is not your source of the problem. You can test it by hooking it up on the scope and spinning it. Should get at least 20V peak to peak at 3000 rpm.
supradjza80
Mr. Formula SAE
Apr 24, 2007
782
Appleton, WI
www.uwracing.com
Well I am not smart enough electronically to know how to properly use a scope (I assume you are saying oscilloscope)...Anyway as promised here is the vid of the idle.
http://www.youtube.com/watch?v=81KKP4mK_YI
