Guys,
My car has a miss at idle and I have gone through and checked everything in the ignition system and believe the only culprit could be my CPS.
I have tried new spark plugs BCPR7ES at .028 just in case my Denso iridiums (IQ20's) were the cause, no change
All of the below items were ohm'd within spec
Plug wires (NGK's changed last fall) all were perfect
Ignition Coils
ISCV
TPS
02 sensor
The only thing that was out of range was the CPS, which ohms about 220-240 ohms on each of the three measurements. Now, I believe based on the above information that this is likely the cause of the miss. But the car starts every time, runs great in boost and has no issues like I would think a bad CPS would cause(random no starts/stalls). Since it is a 500$ part brand new (I want a new one), I would like to be certain it is the cause.
Has anyone else seen the CPS cause this sort of issue, but not have the car have starting/staying running issues?
Thanks,
Dave
Ignition Coils
ISCV
TPS
02 sensor
Thanks,
Dave
