Going back six months ago I noticed the temp gauge raising above the normal 1/3 mark only on the highway. After running a compression, leak down, and block test, it turns out my radiator was clogged.
So I upgraded to a two row aluminum radiator. But before I installed the new radiator, I performed a Oxalic acid flush per JJ's advice here: http://www.supramania.com/forums/sh...eutralized..&p=1559199&viewfull=1#post1559199
Then flushed with distilled water, blew out with air, and filled the new radiator with 50/50 concentration of G05 coolant and distilled water.
Fast forward to now and I am having the same problem but only noticeable in warm weather (70 degress or higher running on highway, needle rises)
So I took a peek inside the radiator and sure enough the same debris as last time floating around in the radiator.
I removed the radiator and back flushed it and here is what came out. I used a makeshift "sluice box" with a tarp to gather the debris here's a pic:
Here's another pic for a size reference:
I then back flushed the engine by taking the thermostat out and running hose water through the top radiator hose and out the bottom into a bucket until I didn't see anymore debris in the bottom of the bucket.
...flushed with distilled water, blew out with air, then filled with 50/50 G05 and distilled water.
Before I put the top radiator hose back on, I took some womens pantyhose, from my collection, and put it on the radiator inlet(top hose) and slid the hose over to act as a easy to clean filter.
After driving 15 min I noticed the gauge creeping to the halfway mark. I turned the heater on to maintain normal temp on the way home.
I took off the hose to see the filter and heres what I saw:
The 22 round is for size reference, it was all I had around...
It feels like the debris is never ending.
My questions:
Is there a better way to filter out the crap? (I feel I am pushing my luck with the HG everytime the engine raises past the normal temp)
Is this common with the 7M?
What is the debris? (the only thing I can think of is iron from the block which is very disturbing)
Or just any advice in general that may be helpful
Thanks for the help......oh and I don't really have a womens pantyhose collection:biglaugh:
My questions:
