Clutch Issue *Pics*
XofXtimeX
Clean 2JZ
Feb 25, 2006
255
Arlington, TX
Well last night after somewhat of a spirited launch (4K RPM slipped, NOT dumped) the clutch stopped engaging altogether. I haven't had any issues with the clutch before this.
The pedal still has pressure however the clutch will not engage or disengage. So today I jacked it up, took the inspection plate off and had someone push the clutch in and I took comparison pictures. I can't tell whether or not it's enough for the clutch to function so hopefully some others will be able to chime in.
Clutch not pushed in:
Clutch pushed in:
I already searched for some clutch issues and I've boiled it down to either slave cylinder (fingers crossed), release bearing or the clutch just went out all together.
Any opinions welcome!
P.S. Its a South Bend Stage 3 OFE (IIRC) full face clutch. Has about 15-18k miles on it. I have not noticed any signs of wear before this happened.
Thanks!!!
-Nick-
charman02
Cruiser
Oct 14, 2008
121
Fresno
Try bleeding your clutch hydraulic system first before any purchase? Check for fluid leaks below your clutch pedal also.
XofXtimeX
Clean 2JZ
Feb 25, 2006
255
Arlington, TX
Well, upon further inspection I've realized that the clutch is acting as if the pedal is being pushed down on the floor constantly and the slave cylinder seems to be working just fine.
When the car is off, I can put the transmission into any gear without a problem WITHOUT pressing the clutch in. I never used to be able to do that. Meaning that when the transmission was working, and the car was off, I was never really able to put the transmission into gear without pushing the clutch in.
I may not be explaining that in the best way so if there is anything that's unclear, please let me know.
Thanks!
-Nick-
RockPaperSwoRD
I have aCustom User Title
Jul 26, 2008
392
SanAntonio
your clutch disc melted onto the flywheel. im not joking.
this happened to me before and i was using the same exact sound bend clutch. the problem is the feramic material.. its a really good clutch but feramic doesnt like to be slipped and overheats and melts.
look up feramic on google and you will see what i mean
this happened to me after i did a burn out...
try turning the engine through the inspection cover(TAKE OFF YOUR EFI FUSE) until you can see the flywheel/ disc thru the pressure plate. then have someone press the clutch pedal while you watch.
if your clutch is still good, you should see the disc separate from the flywheel. i wouldnt crosss my fingers though..
sorry man its a pain in the ass but youre gonna have to swap it out..
XofXtimeX
Clean 2JZ
Feb 25, 2006
255
Arlington, TX
That's exactly what I was afraid of... In case that's really what it is, what's the best plan of attack? Just tilting the engine back (after the mounts are unbolted and all other necessary parts) and getting to the bolts like that? Or should I just pull the engine and transmission both?
Tomorrow I should be able to check on that for sure.
Thanks!
-Nick-
funky_monkey58
Closing in on 200+MPH
Apr 3, 2006
1,307
St.cloud MN
Another issue I have seen with the southbend clutches is the three metal "straps' that act as springs on the pressure plate have been known to fail.
Supra_Villan
needs his car done
Nov 10, 2007
662
Wellsville MO
well...this was not the update i was looking for on this car....
make me happy god damn it!! MORE GOOD VIDS AND PICS LOL...sorry to hear about the clutch man. Good luck.
but seriously..
happy updates.
lintlars
ROOTS RADICALS
Ft.St.John BC
You can get by prying the clutch disk away from the flywheel if its not to stuck I had the same issue with a fullface feramic so have MANY OTHERS go with the 6 puck version still very streetable also stay away from the AL FW with this type of clutch material Stock FW works best
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
My suggestion is to take out the PP bolts and pry it apart. Just be careful when you try to separate the disk. I have done this before in TX2K7, my copper ceramic disk melted to the flywheel. I did the above and the clutch was still good. Good luck
RockPaperSwoRD
Jul 26, 2008
392
SanAntonio
what i did was keep the same pressure plate(was still good) and just bought a 6 puck disc from driftmotion for like ~$150 the biggest pain in the ass is gettin the shaft from the trans to insert into clutch hub. you gotta rotate the trans almost on its side and once its in the hole, spin it again to line up with the car
gaboonviper85
3,236
Northeast Philly
On an r154 you can put the pressure plate and disk on the trans first then all you have too do is line up the shaft too the pilot bearing.....you did it the hard way....
Zach
ECUMaster USA
Apr 6, 2005
375
TX
You do know that you can bolt up the pressure plate AFTER you install the transmission. A hundred times easier to install the trans. if you do it afterward.
5
That's why you don't assemble the flywheel/clutch/pressureplate on the motor. Put the PP and clutch disk on the tranny shaft, put the tranny in, and then tighten the PP to flywheel through the inspection plates (like in the TSRM)
EDIT: damn you guys are quick :rofl:
XofXtimeX
Clean 2JZ
Feb 25, 2006
255
Arlington, TX
Well... I put the rear up on jack stands, started it in gear and slammed on the brakes once it was up to speed. No luck. Higher RPM and no luck. And so on and so forth with no luck.
I guess now I have to get balls enough to drop the car :)
I spoke with southbend, I'm waiting a response.
I suppose thats the other way to do it, if I can't separate it.
Thanks for the help gentlemen!
-Nick-
XofXtimeX
Clean 2JZ
Feb 25, 2006
255
Arlington, TX
How would you guys recommend prying it? Pry bar with a cloth to minimize damage? The pressure plate wouldn't necessarily be too difficult to get off correct? Just seems like a tight fit.
Thanks again guys.
-Nick-
nick88
JayHall's Hero
May 10, 2009
794
Des Moines, Iowa, United States
You could take the c-clip off of the throwout arm and the trans slides off with the pressure plate still on the flywheel.
To take the pressure plate off of the flywheel to pry the clutch, there are six bolts and it comes off. Pry the clutch off make sure it is still useable and bolt pressure plate up using the right torque and sequence.
5
There isn't enough room under the car to get the snout of the tranny into the throwout bearing hub and through the clutch. This is why clutch kits for our cars don't come with clutch alignment tools...
funky_monkey58
Apr 3, 2006
1,307
St.cloud MN
Weird every clutch kit I have seen had an alignment tool.
Just saying.
