changing my head light to non flips ..i got a few questions if possable
spyke_696
25
kittanning
My flippys suck i even put projectors in and its still bad so i plan to change to non flips (im not a fan of flips anyways) so my questions are ... i have a cf hood how will i get the hood up to meet the linght and are there pics u can post of ppl who did non flip conversation
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
Search "honestabe" on these forums. He's still active so he shouldn't be too hard to find. Your hood will be fine, it's the radiator support you'll have to cut. You'll also need to relocate the battery as projector housings stick out quite a far bit out.
spyke_696
25
kittanning
Idk what i want yet but my radd support is fine i can re make one out of fiberglass and ahead of ya my battery is in the back :) what head light fit best with out adding to the hood ..i dont mind cutting it i just dont wanna add cf to my hood it wont look right
spyke_696
25
kittanning
I dont have hids just projectors .... i also dont like the flippys they look goofy ....if i keep them i will do a sleepy eye look but i realy dont want them
If you have quality hids you will be able to see good.
Pop ups look a lot better than flush mounts on theses cars.
Did you look at that link?
Canuckrz
852
Calgary, Alberta
Yes, because the sleepy eyed "flippys" definitely cast a good light :3d_frown: which was your original concern.
I'm gonna go out on a limb and say you bought ebay projector housings and used the bulbs that came with them. Get some nice hella retrofit housings and stuff some phillips Xtreme powers into them for a really great improvement over the sealed beams. Alternitively you could get drop in place HID's IIRC Poodles still makes them.
PS: Putting flushmounts on a mk3 is like putting toothpaste on your prime rib.
kotu100
1,899
Easton, Ma
im with the canuck on this one, you deff need to get some REAL projectors and not that ebay crap. Those ebay "projectors" arnt even functional, they work worse than the clear lense headlights.
moromoto minis with HID's, and some aftermarket headlight housings to retrofit is your most cost effective bet.
destrux
1,183
10
PA
The stock headlights work awesome.... there must have been something wrong with yours if they weren't bright enough. Mine are bright as hell and I just run stock halogen sealed beam bulbs.
Theretrofitsource.com
That has quality hids.
For the "sleepy eyes" that will all be custom. The arms that the motor turns to move the headlight up will need to be modified so they only go up to where you want.
