About a month ago I went to try and pass inspection only to find out my car would fail in a really really bad way... The car has no codes, no check engine light and was running perfectly fine... I had just put in  a new 57 trim from driftmotion.....  The car was doing this before with the old turbo, I expected all white smoke to go away but I still have it when I start the car and when the car berely starts to be driven...  From there on the car does not smoke, atleast I cant see it thru my mirrors and I have only seen someone drive the car around the block.....  A friend told me by looking at the inspection sheet that I was running rich, I changed the O2 sensor but no luck... I am stuck, I have changed the intake manifolds, I have all vsvs, all vacum lines apear to be fine.... Help?
Here is a video of when I started my car early this morning... (click on picture to pull up link to video
And the results from emission....
If anyone has a clue to whts wrong I would greatly appriciate it, been trying to get this car running right for nearly 3 years now.... Rebuilt Block and Head, New 57 Trim agh, I have basically changed almost every part of the original engine.....
 The car seems to be idling a bit rough as time has passed, even at normal running temp it idles at 1000 to 1200 but once you take it out for a spin and put it in park it will go to its smooth 500 to 600....  Thanks to all in advance for any input, all is appriciated
