CajunKenny's Build Thread
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
Tonight was mainly just a cleaning night. I got a lot of brackets, braces, and such cleaned up. I also sprayed the block down with Gunk and Brake Clean. Yep, it removed everything including the paint. Oh well...at least it's clean now... :)
87supradude
living a country song
Jan 19, 2007
62
Salem, OR
way to go man, realy a nice build. I love that you did the trial and error pipes, I did the exact same thing when I made mine LOL. Too much fun and I considered just leaving the light up!LOL. BTW Im in Salem so hopefully I can see her someday.
CajunKenny
Nov 15, 2007
3,255
Washington
He he...yeah, it's an easy mistake to make! At least we're man enough to admit it! :biglaugh:
Oh yeah, I'm sure our paths will cross. I'll be headed to Portland in the spring and of course heading to the Centralia meet too! If you're ever out this way, let me know and we'll do lunch or something!
projectpanda;1475963 said:
what all mods did you have to hit the 294 untuned? and at what PSI
Fidanza 11lb Flywheel
20g Turbo
Carter IC
2" Hardpipe
HKS SuperDragger w/o cat
Downpipe
Fan/Fan Clutch Delete (replaced with Flex-A-Lites)
K&N Fipk
There was other stuff too; but, those are the ones that count. ;)
I had a little more room with my afr's to make more power; but, I didn't want to push it. I could've made about 310.
CajunKenny
Nov 15, 2007
3,255
Washington
At this point, she's starting to look more like a complete engine again.
The rear main seal is in along with the rear timing cover seals. Everything has been torq'd to TSRM Spec and Toyota FIPG used.
Here's a couple shots showing off the newly painted oil pan. You may notice that it's a different shade of blue than in the previous pics. After seeing what 'Ford Blue' looked like, I decided to repaint it 'Old Ford Blue'. It's a bit darker. Me likes better!
CajunKenny
Nov 15, 2007
3,255
Washington
Here's a shot of the Oil Filter Relocation Flange.
I haven't decided where I'm going to mount the filter yet though.
CajunKenny
Nov 15, 2007
3,255
Washington
At this point, I am going to tackle the valve stem seals. I ordered them Monday and they arrived yesterday. I just haven't made it in to town to pick them up yet. Maybe tomorrow...
My tranny has been way laid by a broken bearing. Upon install, the inner race broke. The replacement is scheduled to arrive via UPS tomorrow. I'll pick up that and the valve stem seals in the morning.
Which will be Christmas Eve. Yah!!!!!! :)
SWD Fredester 3
674
baltimore maryland
Good progress. The "old Ford blue" is darker and closer to the valve covers.
Should get them out to you today or monday. 20" of snow here last weekend has slowed things down this week. Thru in a few other pieces as well-Merry Christmas.
CajunKenny
Nov 15, 2007
3,255
Washington
Yeah, that much snow tends to slow things down for sure! I appreciate you getting that stuff out to me and helping me out along the way. :)
Merry Christmas Fred!
CajunKenny
Nov 15, 2007
3,255
Washington
I got the center galley and the cams out. Getting ready to tackle the valve stem seals.
Here's the tool arsenal I chose for the job.
CajunKenny
Nov 15, 2007
3,255
Washington
Here's a shot of all my cam saddles. This is after only around 6k miles. Not too bad; but, worse than I'd hoped to see.
CajunKenny
Nov 15, 2007
3,255
Washington
Here's setup to the block. I chose to use air instead of rope.
I set the cylinder that I was working on to TDC then secured the rotating assembly with a wrench so it wouldn't rotate and suck in a valve.
Using a hose from my compression tester kit, I pressurized each cylinder to ~30psi to keep the valves from falling in to the combustion chamber.
CajunKenny
Nov 15, 2007
3,255
Washington
Everything worked like a champ!
Here's a disassembled upper valve assembly. Note the two small keepers on the right. Don't lose those!
Here's a nasty old valve stem seal.
Here's a new valve stem seal installed.
mkiii racer x
61
st louis
Kenny I read that u did the rack a couple months back how hard was that?
Noticed fluid running out of my split boot when I was changing my oil
mkiii racer x
61
st louis
CajunKenny
Nov 15, 2007
3,255
Washington
Hmm...I think you have me confused with someone else. I've never done a rack. I once dropped the subframe to replace bearings. Could that be what you're remembering?
Sorry... :(
