bov question
gotsomegetsome
Age Quod Agis
Mar 31, 2008
210
san jose
has anyone had any problems with your blow off valve not working??
i have it connected to the tube that originally went to the stock bypass valve but its not opening at all
check the spring, 15psi spring
checked that the valve was oiled properly and not stuck
everything seemed fine but i still cant get it to simply open
Stock setup is dedicated, it just routes in such a way to be pretty (yes they designed the engine to look nice).
It ends up going off that large port off the front of the intake manifold, run a line to it and see if it works then. If it does (so you rule out the BOV), you can clean out and replace the old lines so it doesn't look stupid...
gotsomegetsome
Age Quod Agis
Mar 31, 2008
210
san jose
its a type H BOV
I'll try what poodles said
also, just to make sure, the vacuum tube that connects the stock bypass valve should be connected to the larger part of the vacuum junction underneath the intake manifold correct?
shaeff
Kurt is FTMFW x2!!!!
11
Around
I know the stock one is dedicated, however, it has many places that are susceptible to leaks by design. I mean run one single vacuum hose from the manifold to the BOV. That way there are only two possible locations for a leak in the vacuum source. :)
Yeah, that's what I told him to do to rule out it being the BOV ;)
Though it's a bit ugly, and fixing the factory path isn't hard...
shaeff
11
Around
True. I've been giving serious thought to making SS hardpipes for my vacuum lines. I only have a few of them, anyway. The only problem with that is the fact that I'll have more joints to watch for failure, but overall the line would never leak.
Just something I've been tossing around.
dumbo
1,913
Albera, Too Far North
I drilled and put this fitting in the stock 90 that comes out of the front intake and feeds all the vac lines.
still get bov flutter but it did help.
