blowoff valve vs. bypass valve?
boost fiend
852
Rockford, Il
ok, im thinking about getting a new bov cuz the one i have is kinda cheap. ive heard that a bypass/recerulating valve is better. i understand both sides to the arguement, but i wunder which one might actually be better for my turbo? i get the idea that the bypass valve is better for your turbo's life, but in the terms of making more power, which one seems better?
shaeff
Kurt is FTMFW x2!!!!
11
Around
get an HKS SSQV, and recirculate it back into the intake. :) best of both worlds.
-shaeff
boost fiend
852
Rockford, Il
so bypass should be a lot better in the long run huh? thanx for the insight. i think im going to suprasport today and getting a new valve.
shaeff
11
Around
reasons why recirculation is better:
1) it doesnt bleed out metered air, causing stalling and running rich.
2) it helps to keep the turbo in spool while shifting
reasons why atmospherically venting is better:
1) it sounds cool, (if you're into that type of thing... i'm not)
-shaeff
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
-shaeff
2) blows flames out the exhaust........... :biglaugh:
figgie
Twin Cities, Minnesot-ah
not sure if you know but that is because you are burning unburnt gasses in the exhaust. Now imagine that same gas makes your car move.. what do you think it does to the TURBO ;)
