So dose anyone have know or have a ballpark area where to set my AEM cam grars at with my BC 272 cams? Or has any one set up a set of 272 cams and be willing to share with us where you set them at? I believe it calls out for 8 degrees of overlap. Sorry I also do not have a dyno in my garage
1 mark on gears = 2 degrees of timing)
For anyone that dosent know my set up here it is fresh form my builder. Lower end - Probe .040 over pistions, h-beam connecting rods, lightened crank, entire lower end balance with in 1/2 gram.
Head - full port-polish, BBC comp cam springs, 1mm larger valves, 272 cams, ( know I made it a valve smashing motor now :cry
aem cam gears.
Also gixxer750 what are you using to raise your rev limiter? You full standalone? I think I will have raise mine some day soon, (after fuel system is addressed that is)
